Lexar JumpDrive S37 64GB USB 3.0
Quicklinx: C7S3WS00 Mfr#: LJDS37-64GABEU
  • Stores and transfers content faster with SuperSpeed USB 3.0 technology
  • Securely protects files using EncryptStick™ Lite software, an advanced security solution with 256-bit AES encryption
  • Stylish, swivel design with automatically retractable connector and key ring loop
  • Colorful capacity options
  • Reliably stores and transfers photos, videos, files, and more
  • Compatible with PC and Mac® systems
  • Backwards compatible with USB 2.0 devices
  • Three-year limited warranty
Store and transfer content faster.
With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. The Lexar® JumpDrive® S37 USB 3.0 flash drive offers speeds up to 150MB/s read and 60MB/s write. Quickly transfer a 3GB HD video clip in less than 1 minute, compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices.
Securely protect and delete files on the go.
Looking to protect personal information, financial records, or other sensitive files on the go? Lexar JumpDrive S37 includes EncryptStick™ Lite software, an advanced security solution with 256-bit AES encryption to help protect your essential files against corruption, loss, and deletion. Easily create a password-protected vault that automatically encrypts data. And for peace of mind, files that are deleted from the vault are securely erased and can’t be recovered.
Designed for convenience.
Beyond its performance and good looks, JumpDrive S37 is designed for convenience. Its small slim, swivel design includes an automatically retractable connector, which means there’s no cap to lose. It also has a key ring loop so you can easily attach it to your keychain, computer bag, backpack, or purse.
Colorful style.
Lexar JumpDrive S37 comes in a different color for each of its capacities —from 16GB to 128GB—providing a great color coding system to help you organize your drives and their contents.
When memory matters, the choice is Lexar.
With a long history in the industry, we know memory. We move quickly with technology to design the solutions you need, and work with device manufacturers to make sure our products are compatible. Then we stand behind them with outstanding warranties and helpful customer service. We’re dedicated to performance, reliability, and expert support, so when it comes to storing the memories that matter, trust Lexar.
  • Store and transfer content faster
    With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. The Lexar JumpDrive S37 USB 3.0 flash drive offers speeds up to 150MB/s read and 60MB/s write. Quickly transfer a 3GB HD video clip in less than 1 minute, compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices.
  • Securely protect and delete files on the go
    Looking to protect personal information, financial records, or other sensitive files on the go? Lexar JumpDrive S37 includes EncryptStick Lite software, an advanced security solution with 256-bit AES encryption to help protect your essential files against corruption, loss, and deletion. Easily create a password-protected vault that automatically encrypts data. And for peace of mind, files that are deleted from the vault are securely erased and can't be recovered.
  • Designed for convenience
    Beyond its performance and good looks, JumpDrive S37 is designed for convenience. Its small slim, swivel design includes an automatically retractable connector, which means there's no cap to lose. It also has a key ring loop so you can easily attach it to your keychain, computer bag, backpack, or purse.
Lexar JumpDrive S37 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Encryption Algorithm
256-bit AES
EMEA
Software Included
EncryptStick Lite
3-year warranty
USB flash drive
Storage Capacity
64 GB
256-bit AES
EMEA
Read Rate
Up to 150 MB/s
Write Rate
Up to 60 MB/s
Interface Type
USB 3.0
Retractable connector, swivel cap, key ring loop
Software Included
EncryptStick Lite
Limited warranty - 3 years
50.8 mm
22.4 mm
9.7 mm
4 g
60 °C
95% (non-condensing)
