Lexar 64GB JumpDrive V10
Quicklinx: BJRSWS00 Mfr#: LJDV10-64GABEU
The Lexar JumpDrive V10 USB flash drive provides convenient, reliable portable storage for life on the go. This Hi-Speed USB drive with protective cap provides an excellent solution for safely storing, transferring, and sharing your valuable files, photos, videos, and more.
  • Reliable storage, colorful designs
    Compatible with both PC and Mac systems, the JumpDrive V10 USB flash drive allows you to quickly and easily store a huge number of photo, music, and video files. It has a protective cap design to help safely protect the drive and its contents, and includes a lanyard loop for convenient connection to your key chain or backpack.
  • Plug-and-play design with great features and stylish color
    The drive has a simple plug-and-play design that allows you to quickly and easily store files, so wherever you go, your information goes with you. It also sports an LED activity light that blinks during data transfer, so you know when the job is done and data loss is averted.
  • Lexar performance, quality, compatibility, and reliability
    All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 800 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
Lexar JumpDrive V10 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
64 GB
Enclosure Colour
Purple
USB flash drive
Storage Capacity
64 GB
Enclosure Colour
Purple
Interface Type
USB 2.0
LED access indicator
Lanyard
Plug and Play
