Lexar 64GB Jump Drive M20i USB 3.0/Lightning
Quicklinx: C6S7WS00 Mfr#: LJDM20I-64GBBEU
With today's overflow of content - created, captured, and consumed - it's easy to run out of space on your iPhone or iPad. Now you don't need to delete your favorite photos and videos to make room for more. The Lexar JumpDrive M20i USB 3.0 flash drive expands the memory of your iOS device. No charging or battery needed, and no network required.
  • Save space by offloading files from your device
    With both Lightning and USB 3.0 connectors, this high-speed, 2-in-1 iOS drive makes it easy to move files on the go, so you have extra space to store more of the content you crave.
  • Play music and videos directly from the drive
    JumpDrive M20i not only makes it easy to offload and transfer files, but it also allows you to listen to your favorite songs and watch videos right from the drive.
  • Easily transfer and share files between your iPhone, iPad, and computer
    Use JumpDrive M20i to easily swap your playlists, photos, videos, and files between your iPhone and iPad, or to your computer.
  • Move files at USB 3.0 speeds
    Powered by USB 3.0 performance, JumpDrive M20i provides read speeds up to 95MB/s, so you can quickly transfer a HD video clip in less than one minute - compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices.
  • Convenient portability with retractable design
    JumpDrive M20i sports a thumb slide design, with a retractable connector on each end. This makes it easy to carry and means there are no caps to lose.
Lexar JumpDrive M20i - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0 / Apple Lightning
Storage Capacity
64 GB
3-year warranty (Germany - 10 years)
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 95 MB/s
Write Rate
Up to 20 MB/s
Interface Type
Retractable connector
Limited warranty - 3 years , Germany: limited warranty - 10 years
