Lexar 64GB Jump Drive M20c USB 3.0/Type-C Flash Drive
Quicklinx: C7P3WS00 Mfr#: LJDM20C-64GBBEU
Designed for use with latest generation of devices with USB Type-C connectors, the Lexar JumpDrive M20c USB Type-C flash drive provides a seamless way to move transfer and share content between your Type-C enabled smartphone, tablet, and computer. This high-performance 2-in-1 solution makes quick work of transferring files on the go.
  • Manage your content on the go
    With today's overflow of content - created, captured, and consumed - it's easy to run out of space on your smartphone or tablet. Now you don't need to delete your favorite photos and videos to make room for more.
  • Any which way is up
    No more fumbling to put your USB flash drive in the right way. The USB Type-C connector has a reversible design, so no matter which way you use it, it's the right way.
  • Move files at USB 3.0 speeds
    Powered by USB 3.0 performance, JumpDrive M20c makes quick work of offloading files. With read speeds up to 150MB/s, you can transfer a 3GB HD video clip in less than one minute - compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices.
  • Convenient portability with a protective cap design
    JumpDrive M20c sports a clear end cap with key ring loop, making it easy to attach to a bag or keychain and go.
  • Expand the memory of your USB Type-C mobile devices
    JumpDrive M20c also lets you offload lots of content from your tablet or smartphone to create more room, and also provides a great way to back up files.
Lexar JumpDrive M20c - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0 / USB-C
Storage Capacity
64 GB
3-year warranty (Germany - 10 years)
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 150 MB/s
Write Rate
Up to 60 MB/s
Interface Type
USB 3.0 / USB-C
Retractable connector, USB On-The-Go compatible, key ring loop
Limited warranty - 3 years , Germany: limited warranty - 10 years
