Lexar 64GB 1000X Professional Compact Flash Card
Quicklinx: 83F1WS00 Mfr#: LCF64GCTBEU1000
The Lexar Professional 1000x CompactFlash (CF) memory card provides ultimate high-speed performance and reliability for professional photographers, with industry-leading 1000x (150 MB/s) minimum guaranteed sustained read transfer speed. The card provides support for high-resolution UDMA-enabled DSLR cameras, lets you capture and store high-quality images and 1080p full-HD and 3D video.
  • Ultimate professional-level speed and performance to dramatically accelerate workflow
    The Lexar Professional 1000x CF card leverages the impressive, high-speed performance of UDMA 7 technology to provide industry-leading minimum guaranteed sustained read transfer speed of 1000x (150MB/s) or faster. Performance optimized to leverage the latest photo and video features available in high-end DSLR cameras, it allows you to capture high-quality images and 1080p HD and 3D video, and then transfer from card to computer at blazing-fast speeds. This dramatically accelerates workflow from start to finish, so you can get back to the business of photography.
  • Supports the VPG-20 specification for professional-quality video
    The Lexar Professional 1000x CF card supports the Video Performance Guarantee (VPG-20) specification. This means the card's been tested and guaranteed for professional video capture streams at up to 20 MB/s. This enables professional-quality full-HD video capture at high frame rates with no dropped frames.
  • Unmatched performance, reliability, and compatibility
    The Lexar team works with major camera manufacturers to ensure all Lexar memory cards are compatible with their digital cameras - from the simplest to the most complex. The cards are also tested in the Lexar quality labs, facilities with more than 800 digital cameras and memory card devices, to further ensure compatibility and performance. Designed with professional photographers in mind, the advanced technology and blazing speed of the Lexar Professional 1000x CF card provides ultimate memory card performance.
Lexar Professional UDMA - flash memory card - 64 GB - CompactFlash
Flash memory card
CompactFlash Card
Storage Capacity
64 GB
Speed Rating
1000x
Limited lifetime warranty (Germany - 10 years)
Flash memory card
Storage Capacity
64 GB
Speed Rating
1000x
Read Rate
Up to 150 MB/s
CompactFlash Card
UDMA Mode
Limited warranty - lifetime , Germany: limited warranty - 10 years
