Designed for your sports camcorder, tablet, or smartphone, Lexar High-Performance microSDHC/microSDXC UHS-I card (633x) makes it easy to quickly capture play back, and transfer 1080p full-HD, 3D, and 4k video, as well as the highest-quality movies, photos, and songs. The high-capacity, Class 10 card leverages UHS-I technology to deliver high-speed performance. The cards also come with a USB 3.0 reader for high-speed file transfer. This premium memory solution gives you the speed and space you need to capture more adventure on the go.
Capture adventures in HD with your sports camcorder
Calling all adventure seekers and adrenaline junkies! Now you can make the most of your adventures in the great outdoors by leveraging the power and performance of Lexar high performance micro SDHC/micro SDXC UHS-I card. So whether you're mountain climbing or whitewater rafting, you can quickly capture, play back, and transfer a large amount of the highest quality 1080p full HD, 3D, and 4k video - making it easy to preserve long hours of your greatest moments and then relive the action. -
Do more with your multimedia
Also great for use with your tablet or smartphone, the cards make it easy to quickly download or save all your favorite media files, including the highest-quality movies, photos, and songs. -
Get more from your device
The cards leverage UHS-I technology to deliver a high transfer speed. The premium memory solution gives you the speed and capacity you need to capture, transfer, and share more adventures on the go. -
Quickly transfer files with included reader
The cards also include a USB 3.0 reader to quickly and easily transfer files between your devices. -
Lexar performance, quality, compatibility, and reliability
The Lexar memory card, card reader product designs undergo extensive testing in the Lexar quality labs to ensure performance, quality, compatibility, and reliability.
- Lexar High Performance - flash memory card - 32 GB - microSDHC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDHC UHS-I Memory Card
- Storage Capacity
- 32 GB
- Speed Rating
- UHS Class 1 / Class10 - 633x
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Speed Rating
- 633x
- Speed Class
- Read Rate
- Up to 95 MB/s
- Form Factor
- Included Accessories
- microSD/microSDHC card reader (USB)
- Limited warranty - flash memory card - lifetime , Limited warranty - card reader - 1 year
