One of the fastest USB 3.0 flash drives available, Lexar JumpDrive P20 allows you to quickly transfer files, with speeds up to 400 MB/s read and 270 MB/s write. The drive boasts a sleek metal alloy design and includes EncryptStick Lite software to protect files.
Store and transfer content faster with premium performance
The premium Lexar JumpDrive P20 USB 3.0 flash drive provides fast file transfer, making it one of the fastest USB flash drives available. Now you can transfer a full-length HD movie in less than 40 seconds. And for added versatility, the drive is backwards compatible with USB 2.0 devices. -
Reflect your style with its sleek, metal alloy design
Beyond its powerful capabilities, the drive has a sleek design with a metal alloy base and a high-gloss mirror finish top. What's more, its retractable connector with convenient thumb slide means no lost cap, and its key ring loop makes it easy to attach to your keychain or computer bag and go. With its premium look and feel, JumpDrive P20 is an excellent solution for those looking for a durable and well-designed USB 3.0 flash drive. -
Store more of what matters
JumpDrive P20 opens a world of storage possibilities and allowing you to store more of what matters. -
Lexar performance, quality, compatibility, and reliability
The Lexar memory card, card reader, storage drive, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 1,100 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
- Lexar JumpDrive P20 - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Encryption Algorithm
- 256-bit AES
- Software Included
- EncryptStick Lite
- Limited lifetime warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- 256-bit AES
- Read Rate
- Up to 400 MB/s
- Write Rate
- Up to 150 MB/s
- Interface Type
- USB 3.0
- Retractable connector, metal body, key ring loop
- Software Included
- EncryptStick Lite
- Limited warranty - lifetime
