Quickly and securely transfer photos, videos, and files with the affordable, high-performance Lexar JumpDrive S75 USB 3.0 drive. It features a retractable connector with an easy-to-use thumb slide.
Store and transfer content faster
With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. The drive delivers a very high writing speed. -
Designed for convenience
Beyond its performance and good looks, JumpDrive S75 is designed for convenience. It sports a retractable connector with easy-to-use thumb slide. -
Colorful style
Lexar JumpDrive S75 suits your needs and reflects your personality. It also provides you with a built-in color coding system to help you organize your drives and their contents. -
Lexar performance, quality, compatibility, and reliability
All Lexar USB flash drives ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
- Lexar JumpDrive S75 - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Encryption Algorithm
- 256-bit AES
- Enclosure Colour
- Orange
- Software Included
- EncryptStick Lite
- 3-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- 256-bit AES
- Enclosure Colour
- Orange
- Read Rate
- Up to 150 MB/s
- Write Rate
- Up to 60 MB/s
- Interface Type
- USB 3.0
- Retractable connector
- Software Included
- EncryptStick Lite
- Limited warranty - 3 years
