Easily organize or archive your files with the Lexar® JumpDrive® V20 USB flash drive. It sports a slim design and comes in single or various two, three, or four multipack options in assorted colors. Each drive sports a protective label cover that makes it easy to slide in or swap out labels as needed, and includes write-on labels.
Forget where you stored your photos from last year’s trip? Wondering how to best archive all your tax files? Need a handy way to file class projects and assignments? So whether you prefer to sort by date, file type, or subject, JumpDrive V20 makes quick work of getting your files in order.
JumpDrive V20 is available in single and multipack options in assorted colors with write-on labels, providing a great color-coding system to help you reliably store and organize your drives and their contents. And with a protective label cover, you can easily slide in or swap out labels as needed.
Easily organize or archive files
Forget where you stored your photos from last year's trip? Wondering how to best archive all your tax files? Need a handy way to file class projects and assignments? The Lexar JumpDrive V20 USB multipack makes quick work of getting your files in order. -
Designed for convenience
The JumpDrive V20 USB multipack include 8 GB drive that sport a slim design and provide reliable simple storage for life on the go. Compatible with both PC and Mac systems, the drive allows you to quickly and easily store a large number of photos, files, songs, and videos. Each drive also sports an LED activity light that blinks during data transfer, so you know when the job is done. -
Lexar performance, quality, compatibility, and reliability
This USB flash drive product designs undergo extensive testing in the Lexar quality labs, facilities with more than 1100 digital devices, to ensure performance, quality, compatibility, and reliability.
- Lexar JumpDrive V20 - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 16 GB
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 2-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Interface Type
- USB 2.0
- LED access indicator
- Included Accessories
- Labels
- Limited warranty - 2 years
