Lexar 16GB JumpDrive Twist Turn - Silver
Quicklinx: BCF1WS00 Mfr#: LJDTT16GABEU
Lexar JumpDrive TwistTurn is a high-capacity USB flash drive that provides a convenient solution for storing, transferring, and sharing multimedia and more.
JumpDrive TwistTurn has a simple plug-and-play design that allows you to quickly and easily store files, so wherever you go, your information goes with you. Its durable hinged jacket rotates to easily access a USB port, and it sports an LED activity light that blinks during file transfer, so you know when the job is done. JumpDrive TwistTurn also works across platforms, giving you flexibility and ease of use.
  • High-capacity storage and stylish housing
    The drive has a capless design with a rotating case to protect the drive and its contents, providing an excellent combination of durability and convenience.
  • Plug-and-play design with great features
Lexar JumpDrive TwistTurn - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Enclosure Colour
Silver
Microsoft Certification
Works with Windows Vista
USB flash drive
Storage Capacity
16 GB
Enclosure Colour
Silver
Interface Type
USB 2.0
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
