As powerful as it is portable, the Lenovo Yoga 460 ultrabook is a premium hybrid ready-made for the demands of the business world. It's robust and durable enough for frequent travel, and its extra-long battery life gives you the freedom to work on the go.
Powered by a 2.3GHz Intel i5 dual-core processor, equipped with 8GB memory and offering a 256GB SSD hard drive with OPAL2 support, the Yoga 460 from Lenovo has everything you need to get essential tasks done quickly and easily. Its razor-sharp 14" screen also provides a vivid and colourful display, whichever angle you're viewing it from.
Take your productivity and your creativity to the next level with the Yoga 460's powerful Intel i5 processor and generous memory and storage capacities. Lenovo also provides enterprise-level manageability for enhanced efficiency.
You can easily switch between four modes - laptop, stand, tablet and tent - with system settings that change automatically according to the mode you've chosen. The screen can be flipped around 360 degrees - thanks to Lenovo's improved hinge - or even laid flat.
- Lenovo ThinkPad Yoga 460 - 14" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Ultrabook - flip design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (1 x 8 GB)
- Storage
- 256 GB SSD - TCG Opal Encryption 2
- Display
- 14" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac
- Battery
- 3-cell - up to 8 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0), fingerprint reader
- Black
- 33.8 cm x 23.6 cm x 1.9 cm
- 1.8 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD SATA 6Gb/s - TCG Opal Encryption 2
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- CX11852
- High Definition Audio, Dolby Audio X2
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Technology
- 3-cell lithium polymer
- Capacity
- 53 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , Mini DisplayPort , HDMI , OneLink+ connector , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Lenovo Solution Center, Lenovo Companion, Lenovo Settings, McAfee LiveSafe (30 days trial), SHAREit
- Black
- Case Material
- Carbon fibre
- Integrated Options
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, hard drive password, power-on password, 3D gyrometer, 3D accelerometer, 3D magnetometer, 3D compass, MIL-STD-810G tested
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 1.8 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
