Tablet + PC in one device
The YOGA 300 redefines the essential laptop with 360 degrees of flexibility at an unbelievably low price. Whether for work, play or something in between, the YOGA 300 adapts to you with 4 ways to do almost anything: Laptop, Stand, Tent or Tablet.
360º flip-and-fold design
A PC when you need it, a tablet when you want it, and more. Easily change between four modes - laptop, stand, tent, and tablet. The secret: The 11" Lenovo Yoga 300's unique design and touchscreen display. It allows the screen to flip around 360º, which means you can select the mode you use based on what you choose to do. -
Impressive performance for work and play
Enjoy a PC with the Intel Pentium processor. Experience brilliant PC performance as you multitask effortlessly - communicate with friends and family, enjoy entertainment, and get your work done. Get the impressive performance and quality you've come to expect with an Intel Pentium processor. That's serious processing. Only with Intel inside. -
Windows 10
Windows 10 is the best combination of the Windows you already know, plus lots of great improvements you'll love. Technologies like InstantGo let you boot up and resume quickly, everything runs fast and smooth, and Windows 10 devices now have Battery Saver to automatically conserve power - so you can work longer and play harder. For total confidence, Windows 10 helps you stay up to date and has more built-in security features than ever for helping protect against malicious software. -
Ultra thin, light, portable
Starting at a mere 3.0 lbs and just 0.85" thin, the Yoga 300 is ultra portable - it's perfect for doers on the go. And with up to 8 hours on a standard battery, you can go all day without recharging. -
Harmony
Lenovo Harmony adapts to you by intuitively optimizing settings, making app recommendations by mode, and sharing statistics about how you use your device. -
Stereo speakers
The Yoga 300's speakers deliver rich stereo sound, while Dolby Home Theater provides an immersive audio experience. -
McAfee LiveSafe free trial
Keep your entire digital life secure with the comprehensive protection afforded by McAfee LiveSafe software. LiveSafe protects cross-device, through the cloud, and locally to ensure total security for your data and identity. Enjoy a free 30-day trial with purchase. Or, upgrade to the full version during the purchase process and enjoy peace-of-mind security from day one. -
Lenovo DOit Apps
Do more with your Yoga 300 with premium Lenovo applications like SHAREit, which lets you share files quickly without network charges or a WiFi connection. In addition, SYNCit backs up and restores your contacts and SMSs.
- Lenovo Yoga 300-11IBR - 11.6" - Intel Pentium - N3710 - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Home 64-bit - English
- Processor
- Intel Pentium N3710 / 1.6 GHz, up to 2.56 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 500 GB HDD / 5400 rpm
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 405
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 2-cell
- White
- 29.9 cm x 20.9 cm x 2.18 cm
- 1.4 kg
- Localisation
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.56 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1333 MHz
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 5400 rpm
Display
- 11.6" - TN
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Glossy
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
- Dolby Home Theater
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3160
- Network Interface
- Gigabit Ethernet
- Technology
- 2-cell lithium polymer
- Capacity
- 30 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- 2 x USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack , LAN
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- White
- Administrator password, hard drive password, power-on password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.4 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
