The ThinkPad battery 49+ delivers the greatest battery life for the X300 and X301 series ThinkPad notebooks. This rechargeable, 6-cell battery can be used as a replacement or as a spare. It utilises Lithium-Ion technology and protects against incorrect voltages to ensure your notebook runs at its highest capacity. The current is 11.2 VDC and 2.12 Ah.
*Battery life varies due to many elements, including screen brightness, applications, battery features, conditioning, power management and other customer preferences.
- Lenovo - laptop battery - Li-Ion - 4000 mAh
- Laptop battery
- 300 g
- Battery
- Lithium Ion 6-cell - 4000 mAh
- Battery Form Factor
- Internal
- 25.6 cm x 7.2 cm x 1.3 cm
- 1-year warranty
- Designed For
- ThinkPad X300; X301
- Laptop battery
- Battery Enclosure Type
- Internal
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 4000 mAh
- Recharge Time
- 3 hours
- C-Tick, cUL, UL 60950, ACA
- Limited warranty - replacement - 1 year - carry-in
- 5 °C
- 35 °C
- 8 - 95%
- 25.6 cm
- 7.2 cm
- 1.3 cm
- 300 g
- Designed For
- Lenovo ThinkPad X300 , Lenovo ThinkPad X301
