For a hybrid that offers more than just the ability to do business on the go, Lenovo's ThinkPad X1 combines a great range of impressive features - proving that portability needn't come at the expense of performance.
Next time you're heading off on business, you needn't take your laptop and tablet with you - because the Lenovo ThinkPad X1 is both rolled into one device. It's even equipped with a projector and a 3D camera, and there also optional additional modules including 3D imaging tools as well as docking options, extra ports and more.
Easily portable and capable of handling any business task in any work environment, the ThinkPad X1 features a modular design which allows you to turn the device into a laptop. Its detachable keyboard includes Lenovo's TrackPoint pad, so there's no need for a mouse.
Not only does the X1 deliver a powerful PC experience, but it also offers hours of battery life. Its high-resolution display means you've got a great view from any angle, and it's only 0.3in thin. The Lenovo ThinkPad X1 is so much more than a typical laptop-tablet hybrid.
A tablet with a unique modular design
It is called the ThinkPad X1 Tablet, but it's so much more than your average 2-in-1 hybrid. The unique modular design lets you turn the X1 Tablet into anything from a portable entertainment center, to a creativity device, or a productivity laptop. -
With the power of a PC
The lightweight X1 Tablet is perfect for on-the-go. It delivers a powerful PC experience with a robust processor, and long-lasting battery life. -
Portable entertainment with a stunning display
Whether for work or leisure, the high resolution 2K (2160x1440) display features widescreen IPS technology and an integrated, adjustable kickstand for viewing from any angle. With the integrated speakers and Dolby surround sound technology, the X1 Tablet is perfect for watching videos. -
Let your creativity flow
Draw. Write. Edit documents. Use the stylus pen for sketching, annotating documents, or taking notes. And with Lenovo's exclusive WRITEit technology, you can enter handwriting into any input field across hundreds of apps, and it automatically suggests and corrects your writing. -
ThinkPad keyboard perfection
The X1 Tablet features the detachable keyboard with the legendary ThinkPad design. The built-in TrackPoint and trackpad replicate the feel of an excellent keyboard that's been perfected over more than 20 years. This original keyboard works seamlessly with modules snapped into place. Unlike the classic keyboards, you can adjust the typing angle for greater comfort, accuracy, and speed.
- Lenovo ThinkPad X1 Tablet (1st Gen) - 12" - Intel Core m5 - 6Y54 - 8 GB RAM - 256 GB SSD - 4G LTE-A - UK
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core m5 (6th Gen) - 6Y54 / 1.1 GHz, up to 2.7 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption
- Display
- 12" LED backlight touchscreen 2160 x 1440 / Full HD Plus
- Graphics
- Intel HD Graphics 515
- Input Device
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 4.1
- Wireless Broadband (WWAN)
- 4G LTE Advanced
- Service Provider
- Service not included
- Battery
- 2-cell - up to 10 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Black
- Dimensions (WxDxH) - tablet
- 29.15 cm x 20.95 cm x 1.3 cm
- 795 g
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 3 years - carry-in
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core m5 (6th Gen) 6Y54 / 1.1 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s - TCG Opal Encryption
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2160 x 1440 (Full HD Plus)
- Widescreen
- Image Aspect Ratio
- 3:2
Audio & Video
- Graphics Processor
- Camera
- Sound
- Speaker
Input
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Generation
- 4G
- Technology
- UMTS, HSPA, HSPA+, DC-HSPA+, LTE Advanced
- Controller
- Sierra Wireless EM7455
- Service Provider
Navigation
- Receiver
- GPS
- Technology
- 2-cell Lithium Ion
- Capacity
- 37 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB-C , Mini DisplayPort , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Black
- Dockable
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, keyboard, ThinkPad Pen Pro
- Localization
- TopSeller
- 795 g
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
