Lenovo X1 Carbon Intel Core i7-8550U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: DYM2WS00 Mfr#: 20KH006FUK
  • Core i7
  • IEEE 802.11n
With its stunning look, the ultralight ThinkPad X1 Carbon merges elegant design, seamless responsiveness, and legendary durability to create the ultimate in mobile productivity. RapidCharge technology keep you on-task wherever the road leads. What's more, it weighs less than 2.5 lbs.
  • An IT admin's dream
    ThinkPad X1 Carbon offers robust security features, including ThinkShutter, which covers the front-facing HD webcam, and match-on-chip fingerprint readers with anti-spoofing technology that helps safeguard company data while providing more secure authentication and log-in.
  • Audio so amazing you'll think it's live
    Speakers on the X1 Carbon deliver high-quality sound with Dolby Audio Premium, which energizes your entertainment with rich, powerful sound. It dynamically adjusts audio to deliver home theater quality in a virtual surround sound experience for all your entertainment. Boosted bass and enhanced volume turn it all up for sound that's loud and clear enough to share. And for times you need to plug in your headphones, enter a whole world of sound with Dolby Atmos, for an immersive experience that puts you inside the action.
  • Make your voice heard!
    With Cortana Premium, you can speak commands to your ThinkPad X1 Carbon from 4 meters / 13 feet. The integrated 360-degree far field microphones ensure your voice is heard across the room. Wake your device with a simple phrase. Quickly and easily find files and calendar events. Even put your system into Modern Standby mode, which improves battery performance. So go ahead and speak your mind and boost your productivity at the same time.
  • Built to go on and on
    Like all ThinkPads, the X1 Carbon is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. With a chassis constructed of four layers of reinforced carbon fiber and a magnesium alloy roll-cage for added strength, you'll trust this laptop to handle whatever life throws your way.
  • Flick your finger for privacy
    Minimize concerns about being watched or inadvertently turning on the webcam with ThinkShutter. This built-in sliding cover ensures front-facing camera privacy and security when you opt for the HD camera. It's easy to use and delivers strong protection.
Lenovo ThinkPad X1 Carbon (6th Gen) - 14" - Intel Core i7 - 8550U - 8 GB RAM - 256 GB SSD - 4G LTE-A - UK
Ultrabook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) - 8550U / 1.8 GHz, up to 4 GHz / 8 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, NFC, Bluetooth 4.1, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE Advanced
Service Provider
Service not included
3-cell - up to 19.3 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
32.35 cm x 21.71 cm x 1.595 cm
1.13 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified
1.514 W/kg (body) , 1.514 W/kg (limb)
Limited warranty - 3 years - on-site , Limited warranty - battery - 1 year
Ultrabook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8550U / 1.8 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72%
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3286
High Definition Audio, Dolby Audio Premium
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Generation
4G
LTE Advanced
Controller
FIBOCOM L850-GL - M.2 Card
Service Provider
3-cell Lithium Ion
57 Wh
Run Time
Up to 19.3 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Slots
1 x Nano-SIM card (1 free)
Interfaces Details
USB 3.1 Gen 1 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack , Lenovo Ethernet extension connector , Dock , LAN (on supplied cable)
Memory Card Reader
Yes (microSDXC UHS-II)
Case Material
Glass-fibre reinforced plastic, magnesium alloy, carbon fibre reinforced plastic, polyphenylene sulfide
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
USB-C power adapter, ThinkPad Ethernet Extension Cable Gen 2
RoHS
SAR Value
1.514 W/kg (body), 1.514 W/kg (limb)
Localization
Lenovo TopSeller
1.13 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Essential Accessories (6)
Get more from your purchase from one of our essential accessories
DYM2 Lenovo 3M 14.0W Privacy Filter In Stock £37.80
DYM2 Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.31
DYM2 Lenovo 65W Standard AC Adapter USB-C In Stock £27.98
DYM2 Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.45
DYM2 Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £192.81
DYM2 Kensington Security Cable Lock In Stock £23.62
Other bundles (6)
DYM2 Lenovo HDMI to VGA Monitor Adapter In Stock £22.97
DYM2 Lenovo 2m HDMI Cable In Stock £16.94
DYM2 Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £27.09
DYM2 Lenovo Professional Wireless Keyboard In Stock £52.98
DYM2 Lenovo ThinkPad Ethernet Extension Adapter Gen 2 In Stock £24.74
DYM2 Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
