Lenovo Winbook 2-in-1 N4100 4GB 128GB W10P 11.6" Win 10 Pro
Quicklinx: F4D8WS00 Mfr#: 81M9000NUK
  • Celeron
  • IEEE 802.11n
With powerful processing, a 360-degree hinge that accommodates 4 learning modes, and Pencil Touch technology, Lenovo 300e (2nd Gen) 2-in-1 laptop delivers a premium classroom experience. Factor in durability features like a sealed keyboard, mechanically anchored keys, and drop-resistance, and this convertible is sure to earn the grade.
  • Go ahead, write on the screen!
    The Lenovo 300e (2nd Gen) 2-in-1 laptop features Pencil Touch technology, which means you can use a no. 2 pencil to interact directly on the 10-point multitouch screen - without marking or scratching it up! More accurate than using a finger, Pencil Touch is ideal for taking tests, drawing, and note taking. When you do need finer details and more precision, the optional active electrostatic (AES) pen is at your fingertips - it recharges while garaged so it's always ready.
  • Ready for whatever life throws at it
    Teachers who say the classroom feels like a battleground, take heart - this device has military-grade durability. Built tough with rubber bumpers, reinforced ports and hinges, a sealed keyboard, and mechanically anchored keys, the 300e (2nd Gen) 2-in-1 laptop can handle all manner of shock and awe. It's drop-resistant up to 29.5" (75cm), roughly the height of a school desk.
  • Flexible products for flexible minds
    Thanks to its durable 360-degree hinge, the Lenovo 300e (2nd Gen) 2-in-1 PC can be used in multiple modes depending on the learning environment. Use it in Tablet mode to markup documents. Laptop mode is great for writing essays. Stand and Tent modes help focus students' concentration and foster teamwork.
  • So productive, it almost does your homework
    With its powerful Intel processor, the 300e (2nd Gen) 2-in-1 laptop seamlessly runs Windows 10 and apps from the Microsoft Store. Choose from thousands of interactive education apps, and enjoy learning. Easily work with multiple windows and browser tabs open at the same time.
  • Lighten your load
    With up to 10 hours of battery life, the 300e (2nd Gen) 2-in-1 laptop lasts an entire school day and then some, no need to haul power cords and adapters around. Students can work a full day and take the laptop home to recharge overnight for the next day's classes.
Lenovo 300e (2nd Gen) - 11.6" - Celeron N4100 - 4 GB RAM - 128 GB eMMC - UK
Notebook - flip design
Operating System
Windows 10 Pro National Academic - English
Intel Celeron N4100 / 1.1 GHz (2.4 GHz) / 4 MB Cache
4 GB LPDDR4 (provided memory is soldered)
Storage
128 GB - eMMC
Optical Drive
No optical drive
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel UHD Graphics 600
Input Device
Digitizer, digital pen
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Up to 10 hours
Security
Trusted Platform Module (TPM) Security Chip
29 cm x 20.4 cm x 2.085 cm
1.24 kg
Environmental Standards
TCO Certified Notebooks 8
SAR
0.6 W/kg (body), 0.6 W/kg (limb)
Limited warranty - 1 year - pick-up and return
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
LPDDR4 SDRAM
Speed
2133 MHz
Rated Speed
2400 MHz
Storage
Main Storage
128 GB SSD - (eMMC)
Display
11.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Bezel Type
Flat front
Anti-glare, Pencil Touch technology
Audio & Video
Graphics Processor
Camera
Yes - 720p (front)
Resolution
5 Megapixel (rear)
Sound
Stereo speakers, microphone
Codec
Realtek ALC3287
Input
Keyboard, digitizer, touchpad, digital pen
Keyboard Layout
Spill-resistant, anti-pry key caps
Communications
Wireless
Wireless Controller
M.2 Card
Lithium Ion
42 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
USB 3.0 , USB 3.0 (Always On) , USB-C 3.0 (Power Delivery) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (microSD)
Case Material
Polycarbonate ABS
Security
Administrator password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter, Lenovo Active Pen
RoHS, MIL-STD 810G
SAR Value
Localization
1.24 kg
TCO Certified
