Settle in for serious work with the Lenovo V540 all-in-one, a space-saving, secure desktop engineered for small business. Powered by a high-performance processor, this 23.8" AIO is ergonomically designed to ensure your comfort - as well as maximizing your productivity - when the workday extends into the evening.
Commanding performance
Don't waste time. PCIe SSD storage and DDR4 memory mean speedy boot-ups, quick file loading, and faster system performance. The Lenovo V540 AIO's advanced processing delivers the power you need to conquer your to-do list. -
Robust security
The trusted platform module (TPM) encrypts all sensitive data on your Lenovo V540 to keep your business-critical information safe. You decide when your HD webcam is broadcasting thanks to its physical privacy cover. -
Comfortable user experience
Long hours? No problem. The 23.8" borderless, wide-view-angle FHD display delivers crisp visuals. The Ultra Low Noise and Low Blue Light certifications let you work longer, with less eyestrain and distraction. -
Advanced ergonomics
The ergonomic stand lets you tilt and swivel the display so it's most comfortable for you. And the Lenovo V540 is easy to install thanks to a latch design - and you can even use a VESA mount to attach it to a wall for increased desk space.
- Lenovo V540-24IWL AIO - all-in-one - Core i5 8265U 1.6 GHz - 8 GB - HDD 1 TB - LED 23.8" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) (Quad-Core)
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 5400 rpm
- Optical Storage
- No optical drive
- Card Reader
- 3 in 1
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel UHD Graphics 620
- Camera
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Home 64-bit Edition
- Software Included
- McAfee LiveSafe (30 days trial), Lenovo Vantage
- Black
- 54.1 cm x 21.4 cm x 45 cm
- 6.4 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Stereo speakers
- Embedded Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 1.6 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 0 (empty)
- Dual channel memory architecture
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Card Reader
- 3 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- LED
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare, Wide Viewing Angle, borderless
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution
- 720p
- LED indicator, privacy shutter
Input Device
- Keyboard, no mouse
Keyboard
- Keyboard Name
- Lenovo Calliope Keyboard
- Connectivity
- Wireless
- Interface
- RF
- Localization & Layout
- UK
Audio Input
- Dual array microphone
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Slots
- 2 (total) / 1 (free) x M.2 Card
- 2 x USB 3.1 Gen 2 (1 front, 1 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI input , 1 x HDMI output , 1 x headphones/microphone (1 in front)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- TUV Rheinland Low Blue Light Certification, TUV Rheinland Ultra Low Noise Certification
- TopSeller
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Windows 10 Home 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Dimensions & Weight Details
- 54.1 cm - 21.4 cm - 45 cm - 6.4 kg - with stand , 54.1 cm - 5.97 cm - 33.7 cm - 4.8 kg - without stand
- 54.1 cm
- 21.4 cm
- 45 cm
- 6.4 kg
Warranties (1)
Lenovo ePac On-site Repair from 1 to 3Yrs | In Stock | £64.29 |
Monitors (4)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £321.24 |
Keyboards and Mice (2)
Lenovo Professional Wireless Keyboard | In Stock | £54.36 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Other bundles (2)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Kensington Security Cable Lock | In Stock | £23.65 |
