Lenovo V530 AIO 21.5"  - Ci5-8400T 8GB 1TB Win 10
Quicklinx: F1L9WS00 Mfr#: 10US000DUK
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
Hurry, only 1 left in stock!
£657.05 ex VAT
£788.46 inc VAT
Robust, reliable, and secure, the Lenovo V530 AIO walks the walk and talks the talk. Powered by the latest Intel processors, with high-speed memory and storage, it's designed with productivity and energy efficiency in mind. With its pin-sharp borderless display, this space-saving all-in-one will brighten up any desk - and your business prospects, too.
  • Optimized for IT - and business
    Designed with IT and end-users in mind, the highly-responsive Lenovo V Series AIOs are easy to set up, deploy, use, and manage. Engineered for energy efficiency, they undergo stringent testing to ensure that they can perform in the most challenging environments. As well as helping you maximize productivity, they have robust security features to safeguard your critical data and built-in reliability that your business can count on.
  • The power to empower your business
    When it comes to performance and responsiveness, the Lenovo V530 AIO punches way above its starting weight of 5.6 kg. With up to 8th Gen Intel Core i7 processing power and 16 GB of high-speed memory, plus a choice of storage options, your productivity and efficiency levels are set to soar.
  • The powerful Lenovo V530 AIO makes multitasking a breeze
    Every V530 AIO is equipped with Smart USB Protection and TPM, or Trusted Platform Module. The first feature enables you to restrict the USB devices that can access your PC, the other provides hardware-based security should the system be tampered with.
  • You can never be too careful
    For extra peace of mind, you can open and close the webcam with the push of a button. So there's no need to spoil the nice, clean look of the 21.5" borderless display with sticky tape or notes to cover up the camera.
  • Great for any business & workspace
    At home in almost any environment, V530 AIO's durability and reliability mean good value for any business. It's great for IT managers, too, who can tap into Lenovo Vantage tools to help optimize system performance and protect data. And the rear cable holder is perfect for those who like a neat desk.
Lenovo V530-22ICB - all-in-one - Core i5 8400T 1.7 GHz - 8 GB - 1 TB - LED 21.5"
Personal computer - all-in-one
1 x Intel Core i5 (8th Gen) 8400T / 1.7 GHz (3.3 GHz) (6-core)
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
1 x 1 TB - SATA 6Gb/s - 5400 rpm
Optical Storage
DVD-Writer
Card Reader
3 in 1
Monitor
21.5" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel UHD Graphics 630
Camera
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
OS Provided
49.02 cm x 22.8 cm x 40.87 cm
6.1 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site
Personal computer
Product Form Factor
All-in-one - with monitor stand
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 16 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, Wide Viewing Angle, borderless, Advanced In-Cell Touch (AIT) technology
Graphics Controller
Graphics Processor
Video Interfaces
HDMI
Audio Output
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution
720p
LED indicator, privacy shutter
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Lenovo Calliope Keyboard
USB
Mouse
USB
Audio Input
Microphone
Ethernet Controller
Realtek RTL8111G
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3165
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Wake on LAN (WoL)
Slots
2 (total) / 1 (free) x M.2 Card
1 x USB 3.1 Gen 2 , 2 x USB 3.1 Gen 1 , 3 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI input , 1 x HDMI output , 1 x headphones/microphone
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
TopSeller
Power adapter
Nominal Voltage
Power Provided
90 Watt
Efficiency
88%
Operating System / Software
OS Provided
Software
McAfee LiveSafe (30 days trial), Lenovo App Explorer, Lenovo Vantage
ENERGY STAR Certified
ENERGY STAR Version
7.0
49.02 cm
22.8 cm
40.87 cm
6.1 kg
Lenovo V530 AIO 21.5 Bundle deal on Lenovo V530 AIO 21.5" - Ci5-8400T 8GB 1TB Win 10
£842.27
saving £8.33
£756.81
Keyboards and Mice (1)
F1L9 Lenovo Optical 3-button W/Mouse USB In Stock £13.60
Other bundles (1)
F1L9 Lenovo Microsaver Security Cable Lock In Stock £34.15
Storage Type: HDD
Processor Model: I5-8400T
Type: Personal computer
Case Style: All-in-one
Optical Storage: DVD-Writer
Brand: Lenovo
Price Range Ex VAT: 500 - 750
