Take care of business
Whether you’re running a spreadsheet, teleconferencing, managing files, or tackling other jobs, the 14" Lenovo V14 laptop will handle your needs efficiently. Designed to keep you productive and your data secure, it’s a dependable everyday business partner. And its slimmer, smaller design—with narrower bezels—gives your business a sleek, professional face.
Enhanced productivity & security
Dual storage options and optional NVIDIA® dedicated graphics contribute to enhanced productivity, while the integrated firmware—Trusted Platform Module (TPM) 2.0—keeps your work secure by encrypting data and passwords.
Visual style
The contemporary design of this sleek, Iron Gray laptop gives it a premium look and feel—especially the optional in-mold rolling (IMR) cover with textured lines—and its slim body travels well when you’re not in the office. The optional FHD (1920 x 1080) 14" screen, now with narrower side bezels for a better visual experience, displays colors beautifully and gives clarity to videos, images, and text.
Extreme dependability
We tested this laptop for reliability and durability against eight extreme conditions: shock test; vibration test, keyboard in-system test, hinge life test, fan reliability test, panel scuff test, operating temperature test, and pressure test. It’s ready for whatever conditions your business can put it through.
Organizational assistance
Start with Windows 10 Pro, which includes your own personal assistant—Cortana. You’ll never have to hunt for files or photos or meetings again; let Cortana do the work for you. Integrate Cortana with your calendar and you can even search by when and whom you worked on a file with, rather than having to remember file names.
Contemporary design
Choice of two exterior covers that look and feel premium and a slim body that is less than 20mm thick, being easy to carry around is just the icing on the cake. -
Powerful performance
Experience high responsiveness even while working on multiple applications. The DDR4 memory, and M.2 PCIe SSD support along with dual drive storage allows you to do more and do it faster. -
Enhanced user experience
The anti-glare FHD feature is easy on the eyes. It displays colors beautifully and offers clarity to videos, images, and texts, just the way it is intended to be. -
Ample connectivity
With multiple connectivity options built into the laptop, including USB 3.0 and HDMI ports, you get more options to effortlessly run multiple devices at once than most other laptops in its class. -
Better security
The TPM 2.0 firmware prevents tampering with onboard data, secures the PIN, and encrypts passwords, ensuring the safety and security of your confidential files.
- Lenovo V14-IWL - 14" - Intel Core i5 - 8265U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i5 (8th Gen) - 8265U / 1.6 GHz, up to 3.9 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- Up to 6 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Iron grey
- 32.71 cm x 24.1 cm x 1.99 cm
- 2.1 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Integrated memory controller
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 1200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 2242 PCIe 3.0 x2 - NVM Express (NVMe)
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Intel UHD Graphics - up to
- Camera
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
- High Definition Audio, Dolby Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad, buttonless touchpad
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- Lithium Ion
- Capacity
- 35 Wh
- Run Time
- Up to 6 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- USB 2.0 , 2 x USB 3.1 Gen 1 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Office (Trial)
- Iron grey
- Case Material
- Polycarbonate ABS
- Security
- Administrator password, hard drive password
- Included Accessories
- Power adapter
- RoHS, Energy-Related Products (ErP) Lot 3
- Localization
- 2.1 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo 3Y On Site Warratny | In Stock | £46.57 |
Other bundles (2)
Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 | In Stock | £27.09 |
Lenovo Professional Wireless Keyboard | In Stock | £52.94 |
