Lenovo V14 G2 ITL Intel Core i5-1135G7 8GB 256GB SSD 14" Windows 11 Professional 64-bit
Quicklinx: GYDMWS00 Mfr#: 82KA00NFUK
  • Core i5
  • IEEE 802.11n
If you have a fixed budget but still need to support more mobile workers, consider this 14" entry-level laptop. It comes with fast charging, Dolby Audio, and a narrow frame around the display which reduces the overall footprint of the device.
  • Power your business
    Take on your everyday workload with ease, thanks to a choice of up to 11 th Gen Intel processors and optional NVIDIA GeForce MX350 discrete graphics. The Lenovo V14 Gen 2 (14" Intel) laptop also boasts up to Windows 11 Pro, which lets you enjoy unmatched efficiency and responsiveness. And with up to 16GB memory and a hybrid combination of up to 512GB M.2 PCIe SSD and 2TB HDD storage, multitasking is seamless.
  • Designed to impress
    At 19.9mm/ 0.78" and 1.5kg, the V14 Gen 2 laptop is sleek and portable. Choose from two color options: Iron Gray with in-mold rolling (IMR) textured lines on two sides or Black with a special tactile texture on three sides.* Make an impression.*Color varies depending upon CPU.
  • Immersive viewing
    The 14" display, with four-sided narrow bezels, gives the V14 Gen 2 laptop an 88% screen-to-body ratio. Avoid distractions and focus on the FHD (1920 x 1080) antiglare display, or choose the HD (1366 x 768) TN panel if rich detail is less important to your work.
  • Encryption, malware protection,& more
    Windows 11 Pro delivers powerful built-in security, including hardware-based isolation, encryption, and malware protection. Additionally, Zero Trust security combines secure device attributes with multifactor authentication to protect corporate identity and data. Trusted Platform Module (TPM) 2.0 firmware encrypts critical business data, while a physical webcam shutter ensures outsiders can't see you unless you want them to.
  • Warranty Upgrades
    Onsite Service maximizes PC uptime and productivity by providing convenient, fast repair service at your place. In addition, with Tech Install CRU service the installation of all internal Customer Replaceable Unit (CRU) parts will be done on your behalf by a trained technician. 1
  • Warranty Extensions
    This fixed-term, fixed-cost service help you accurately budget for PC expenses, protect your investment, and lower the cost of ownership over time. 1
  • Keep Your Drive
    Retain your drive if it should happen to fail, giving you the peace of mind of knowing that your valuable data is secure. 1, 2
Lenovo V14 G2 ITL - 14" - Intel Core i5 - 1135G7 - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 11 Pro - English
Intel Core i5 (11th Gen) - 1135G7 / 2.4 GHz, up to 4.2 GHz / 8 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel Iris Xe Graphics
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
Up to 6 hours
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
32.42 cm x 21.52 cm x 1.99 cm
1.6 kg
Manufacturer Selling Program
Lenovo TopSeller
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 11 Pro - English
Processor / Chipset
CPU
Intel Core i5 (11th Gen) 1135G7 / 2.4 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
8 MB
Integrated memory controller
RAM
8 GB (provided memory is soldered)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
1600 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2242 PCIe 3.0 x4 - NVM Express (NVMe)
Display
14" - TN
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Colour Gamut
45% NTSC
Anti-glare, 90° viewing angle
Audio & Video
Graphics Processor
Intel Iris Xe Graphics - up to
Memory Allocation Technology
Shared Video Memory (UMA)
Max Monitors Supported
1 external monitor(s)
Camera
Yes - 720p
Camera Features
Privacy shutter, fixed focus
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad, precision touchpad
Communications
Wireless
Wireless Controller
M.2 Card
Network Interface
Gigabit Ethernet
Dual stream (2x2)
Lithium polymer
38 Wh
Run Time
Up to 6 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt
Connections & Expansion
Interfaces Details
USB 2.0 , USB 3.2 Gen 1 , USB-C 3.2 Gen 1 (data only) , HDMI , Headphone/microphone combo jack , LAN
Software
Software Included
Microsoft Office (Trial)
Case Material
Polycarbonate ABS
Surface Finish
Texture
Security
Administrator password, hard drive password, power-on password, RapidCharge
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
Wall mount power adapter
RoHS, TUV Rheinland Low Blue Light Certification, Energy-Related Products (ErP) Lot 3
Localization
Lenovo TopSeller
1.6 kg
Sustainability Information
TCO Certified
5 °C
35 °C
8 - 95%
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
GYDM Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £193.72
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
GYDM Lenovo 3Y On Site Warratny In Stock £46.46
Other bundles (5)
GYDM Lenovo Essential Wireless Keyboard and Mouse Combo - UK English 166 In Stock £27.09
GYDM Lenovo Professional Wireless Keyboard In Stock £52.93
GYDM Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
GYDM Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.79
GYDM Lenovo ThinkVision T24t-20 23.8" 4ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £295.62
