The V130 15.6" laptop delivers great performance in a patterned, textured cover that bespeaks modern style. A simple, clean design features a large, one-piece touchpad and hinges that open 180 degrees - perfect for collaborating. Powerful Intel technology keeps you working productively, while enhanced security protects your critical data.
An IT admin's dream
The V130 small-business laptop is perfectly portable - yet it features powerful processing, so it's a cinch to work with anywhere. -
No matter what your angle
The V130 delivers rich visuals no matter what you're doing. Complete your project. Be creative. Watch a movie. The 15.6" screen opens 180 degrees, making it simple to share and collaborate, or just get comfortable with your laptop at the angle you want. And with stereo speakers and Dolby Audio no matter what you're listening to, it's sure to sound as good as it looks. -
Think outside the cubicle
The full-sized, ergonomic keyboard on the V130 was engineered for comfort and typing accuracy. The large touchpad makes it even easier to be productive wherever you are - no mouse required - and the one-piece design looks sleek. This keyboard is also spill-resistant, so you can go about your business without concern for the little mishaps of daily life. -
Built for business, tested for life
V Series laptops undergo reliability and durability checks to ensure they run smoothly for years to come. From withstanding shocks and vibrations to enduring the rigors of daily handling. From hinge-life testing to fan reliability, operating temperatures, pressure tests, and more.
- Lenovo V130-15IKB - 15.6" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
- Storage
- 256 GB SSD
- Optical Drive
- DVD-Writer
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 2-cell - up to 6 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Iron grey
- 37.5 cm x 25.3 cm x 2.23 cm
- 1.8 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Specific Absorption Rate (SAR)
- 0.443 W/kg (body) , 0.443 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7500U / 2.7 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- RAM
- 8 GB (1 x 4 GB + 4 GB (soldered))
- Max RAM Supported
- 12 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 1067 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - SanDisk
- Optical Drive
- DVD-Writer - tray
Display
- 15.6" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Intel HD Graphics 620 - up to
- Camera
- Yes - 720p
- Sound
- Stereo speakers, microphone
- Dolby Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 2-cell Lithium Ion
- Capacity
- 30 Wh
- Run Time
- Up to 6 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 20 V, 2.25 A
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Iron grey
- Case Material
- Polycarbonate ABS
- Security
- Administrator password, hard drive password, power-on password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington mini security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- 1.8 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo 3Y On Site Warratny | In Stock | £46.46 |
Other bundles (1)
Lenovo Professional Wireless Keyboard | In Stock | £52.93 |
