Lenovo V110-15AST 80TD A9 9410 8GB 128GB SSD 15.6" Windows 10 Pro
Quicklinx: DVF6WS00 Mfr#: 80TD005JUK
  • IEEE 802.11n
  • Superior performance
    Enjoy a high-performance PC benchmark with powerful processors. Offering built-in security, these processors brimming with power and features are ready to take your productivity, creativity and entertainment to unprecedented levels. Best of all, by keeping Windows 10 and its exceptional features running at peak performance, powerful processors expand your possibilities to infinity, giving you the means to let your imagination run wild.
  • Anti-glare screen
    The Lenovo V110's optional 15.6" HD display delivers a crisp, bright 16:9 aspect ratio. It also benefits from anti-reflective technology that can reduce the risk of eye fatigue.
  • Lightweight and robust
    Extremely thin and light, the Lenovo V110 is designed to let you work wherever you are. What's more, the keyboard keys have no deep crevices. This greatly reduces the accumulation of dust and dirt, which can degrade performance over time.
  • Secure and adapted to the business world
    You can never be too careful when it comes to IT security and data breaches. That's why the industry-certified Trusted Platform Module is built into the Lenovo V110, enabling file encryption, password protection, boot protection and more. The V110 also boasts a range of ports, including ultra-fast USB 3.0 and HDMI.
  • Vast storage space
    With abundant storage space, you can easily store all your documents, photos and other digital files.
  • Hinge for horizontal screen positioning
    The Lenovo V110's hinge can open to 180 degrees, ideal when you want to share your screen with others.
Lenovo V110-15AST - 15.6" - AMD A9 - 9410 - 8 GB RAM - 128 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
AMD A9 9410 / 2.9 GHz, up to 3.5 GHz / 1 MB Cache
8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
Storage
128 GB SSD
Optical Drive
DVD-Writer
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R5
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
3-cell - up to 6 hours
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Black texture
38 cm x 26.2 cm x 2.29 cm
1.9 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
Integrated memory controller
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
8 GB
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
1067 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
128 GB SSD 2.5" (5 mm) SATA 6Gb/s - Samsung
Optical Drive
DVD-Writer - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
AMD Radeon R5 - up to
Camera
Resolution
0.3 Megapixel
Sound
Speaker, microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Realtek RTL8821AE - M.2 Card
Network Interface
Gigabit Ethernet
3-cell Lithium Ion
24 Wh
Run Time
Up to 6 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
USB 3.0 , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Black texture
Case Material
Polycarbonate ABS
Security
Administrator password, hard drive password, power-on password
Theft/Intrusion Protection
Security Slot Type
Kensington mini security slot
Power adapter
RoHS
Localization
1.9 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
