With powerful processor and advanced memory - the Lenovo V520S small form factor is designed to boost your productivity. Combined with performance-enhancing hard drive - you have speed and power at your fingertips as you handle large files, create rich content, and stay in touch. With 4 forward-facing USB ports, you can connect your peripherals, and adapt as your business grows. Your V520S small form factor delivers security, simplicity, and productivity - helping you drive your business forward.
Powerful performance
Make business-boosting productivity your first choice with powerful processor - together with fast hard drive, advanced memory to power up in a flash, load files fast and avoid frustrating delays. -
Future ready
You're fully equipped for easy upgrade to Intel Optane memory - enabling you to get even more amazing performance and responsiveness without compromising on storage. -
Enhanced security
With smart USB protection for preventing sensitive business data from leaking - you have the reassurance of optimized security features.
- Lenovo V520S-08IKL - SFF - Core i3 7100 3.9 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Smart Cache
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 7 in 1
- Graphics Controller
- Intel HD Graphics 630
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 26.05 cm x 34.35 cm x 8.9 cm
- 4.75 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Embedded Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip
- Black
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.9 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel B250
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- DVD-Writer - SATA
Card Reader
- 7 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Lenovo Calliope Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- Lenovo Calliope Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111GN
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x1 - low-profile , 2 (total) / 2 (free) x M.2 Card
- 6 x USB 3.0 (4 front, 2 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x VGA , 1 x DisplayPort , 1 x HDMI
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- RoHS, GREENGUARD, Energy-Related Products (ErP) Lot 3
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- Efficiency
- 85%
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 26.05 cm
- 34.35 cm
- 8.9 cm
- 4.75 kg
