The Lenovo Universal USB 3.0 to VGA/HDMI Adapter turns an available USB 3.0 port into a display port offering either VGA or HDMI output with support for high-definition 1080p and with audio. The adapter delivers a convenient external video solution that makes it easy to add multi-monitor capability to a USB-enabled desktop or laptop computer. Leveraging the USB 3.0 SuperSpeed interface, the USB video adapter functions as a convenient external graphics card - no additional graphics card required. The adapter delivers smooth, high-definition content to multiple displays. With two video output ports, the dual-head design of the adapter offers a compact multi-monitor solution across both VGA and HDMI technology. The adapter is installed externally through USB, which enables you to add graphics capability to your system without adding a new graphics card.
- Lenovo Universal USB 3.0 to VGA/HDMI Adapter - external video adapter
- External video adapter
- Bus Type
- SuperSpeed USB 3.0
- Max Resolution
- 2560 x 1440
- Interfaces Details
- VGA , HDMI
- 3.7 cm 14.2 cm
- Length
- 20.7 cm
- 1-year warranty
- Bus Type
- Max Resolution
- 2560 x 1440
- VGA , HDMI
- OS Required
- Microsoft Windows 7 64-bit Edition, Windows 8 64-bit Edition, Windows 8.1, Microsoft Windows 7 32-bit Edition
- Cables Included
- 1 x USB cable
- VCCI, C-Tick, BSMI, CB, EMC, FCC, ICES, KC
- 3.7 cm
- 14.2 cm
- Length
- 20.7 cm
- 110 g
- Limited warranty - replacement - 1 year
- -5 °C
- 40 °C
- 20 - 95%
