Lenovo USB-C To USB-C Cable - 2m
Quicklinx: FCDSWS00 Mfr#: 4X90Q59480
30 In Stock
£31.50 ex VAT
£37.80 inc VAT
The Lenovo USB-C to USB-C Cable 2m makes it easy to connect your USB-C notebook with other USB-C accessories and displays that are slightly out of reach. It supports a 5Gbps data rate, 20V/3A 60W power, and can be used with USB-C Docks, USB-C monitors with 4K video, and other USB-C devices. It is extra-long at 2m (6'6"), with a cable management strap.
Lenovo - USB cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
20 V
Rated Current
3 A
Works With Chromebook
1-year warranty
USB cable
Rated Voltage
20 V
Rated Current
3 A
Length
2 m
Connector
24 pin USB-C - male
24 pin USB-C - male
1-year warranty
Brand: Lenovo
