The Lenovo USB-C to USB-C Cable 2m makes it easy to connect your USB-C notebook with other USB-C accessories and displays that are slightly out of reach. It supports a 5Gbps data rate, 20V/3A 60W power, and can be used with USB-C Docks, USB-C monitors with 4K video, and other USB-C devices. It is extra-long at 2m (6'6"), with a cable management strap.
- Lenovo - USB cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB cable
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 20 V
- Rated Current
- 3 A
- Works With Chromebook
- 1-year warranty
- USB cable
- Rated Voltage
- 20 V
- Rated Current
- 3 A
- Length
- 2 m
- Connector
- 1-year warranty
