The Lenovo USB-C to USB-C Cable 2m makes it easy to connect your USB-C notebook with other USB-C accessories and displays that are slightly out of reach. It supports a 5Gbps data rate, 20V/3A 60W power, and can be used with USB-C Docks, USB-C monitors with 4K video, and other USB-C devices. It is extra-long at 2m (6'6"), with a cable management strap.
Efficient connectivity
This Lenovo USB cable is designed to provide a reliable connection between your devices, ensuring efficient data transfer and power delivery. With a rated current of 3 A and a voltage of 20 V, it supports fast charging and secure data synchronization for a seamless user experience. -
Universal compatibility
Featuring a 24 pin USB-C connector on both ends, this cable offers versatile connectivity options. It's compatible with a wide range of devices, making it a practical choice for connecting smartphones, tablets, laptops, and more. Its compatibility with Chromebook further enhances its utility in diverse environments.
- Lenovo - USB cable - USB-C to USB-C - 2 m
- USB cable
- Cable Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 20 V
- Rated Current
- 3 A
- Works With Chromebook
- 1-year warranty
- Designed For
- ThinkPad T16 Gen 4 21QN
- USB cable
- Rated Voltage
- 20 V
- Rated Current
- 3 A
- Cable Length
- 2 m
- Connector
- 1-year warranty
- Designed For
- Lenovo ThinkPad T16 Gen 4 21QN
