Lenovo USB 3.0 to DVI/VGA Monitor Adapter
Quicklinx: 8H6BWS00 Mfr#: 0B47072
USB is ubiquitous. The Lenovo USB 3.0 to DVI/VGA Monitor Adapter (0B47072) provides a quick and easy way to attach an analog or digital monitor to a ThinkPad or ThinkCentre USB port, helping to increase productivity through the use of multiple monitors.
The Lenovo USB 3.0 to DVI/VGA Monitor Adapter is ideal for increasing the efficiency of everyday tasks. View and extend spreadsheets across multiple monitors, or view financial charts simultaneously. Using multiple USB 3.0 to DVI/VGA Monitor Adapters reduces overlapping of windows when multitasking is required, and increases overall user experience and productivity. Adapters coexist with existing system monitor ports and installed graphics cards.
  • Versatile connectivity
    The Lenovo USB 3.0 to DVI/VGA Monitor Adapter offers a seamless connection to both DVI and VGA displays, ensuring compatibility with a wide range of monitors and projectors. This flexibility allows users to extend or mirror their desktops to increase productivity and enhance their computing experience.
  • High resolution support
    With support for resolutions up to 2048 x 1152, this external video adapter delivers clear, detailed images for professional presentations, graphic design, and video streaming. The high resolution ensures that text is sharp and easy to read, while colors are accurately reproduced.
  • Easy installation
    Designed for simplicity, the adapter connects to a PC via a SuperSpeed USB 3.0 interface, offering a Plug-and-Play solution without the need for additional power sources or software installations. This ease of use makes it an ideal solution for dynamic work environments and on-the-go presentations.
Lenovo USB 3.0 to DVI/VGA Monitor Adapter - external video adapter
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
- up to
Max Resolution
2048 x 1152
Interfaces Details
DVI-I , VGA - with adapter
5 cm x 8 cm x 2.5 cm
1-year warranty
Bus Type
SuperSpeed USB 3.0
Max Resolution
2048 x 1152
Interfaces Details
1 x USB cable - 70 cm , 1 x DVI-VGA adapter
Software Included
Driver
C-Tick, CB, FCC, VCCI, KC
5 cm
8 cm
2.5 cm
138 g
Limited warranty - 1 year
5 - 90%
