WHO NEEDS THINKPAD 10? 1. Enterprises and SMEs looking for a single powerful device that is easily portable and delivers a full PC experience in any work environment.2. Professionals who need to be productive all day long, wherever they are – in the office, at home or on the go.3. Business professionals who refuse to sacrifice power for versatility and want the ability to handle business tasks wherever they are.4. People who require a totally versatile mobile device with the flexibility to work anywhere in Tablet, Stand, Desktop or Laptop mode.
Powerful processors
With stunning visuals and performance, the fast processor delivers processing power that takes your computing to the next level so that you can work smarter and play harder. Enjoy amazing battery life that keeps you productive on the go so that you don't have to worry about recharging. That's serious processing. -
Four awesome modes in one incredible device
Easily change between four modes - laptop, stand, tablet, and tent - while your system automatically switches system settings and locks the keyboard in place. The secret: ThinkPad Yoga 260's unique design, improved hinge, and touchscreen display allow the screen to flip around 360 degrees - and even lay flat - which means you can select the mode you use based on what you choose to do. -
Thin and light design with long battery life
ThinkPad Yoga 260 is ultra-portable - it's perfect for productivity on the go. And with many hours of battery life, you can go all day without recharging. -
Multi-mode backlit keyboard
The ThinkPad Yoga 260's advanced lift-and-lock keyboard fits the bill. When your Yoga switches between modes, the keyboard frame automatically rises and the keys lock, eliminating accidental keystrokes and providing a more comfortable grip. Plus, backlit keys makes for easy typing in low-light environments. -
Extra security features
You can rest assured knowing your data and hardware are safe, thanks to features such as DTPM encryption and a smart card reader, fingerprint touch reader, and Kensington lock.
- Lenovo ThinkPad Yoga 260 - 12.5" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD - 4G LTE-A - UK
- Product Type
- Ultrabook - flip design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD - TCG Opal Encryption 2
- Display
- 12.5" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Input Device
- Digitizer, TrackPoint, digital pen, UltraNav
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, NFC, Bluetooth 4.1
- Wireless Broadband (WWAN)
- 4G LTE Advanced
- Service Provider
- Lenovo
- Battery
- 4-cell - up to 10 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0), fingerprint reader, smart card reader
- Midnight black
- 30.99 cm x 22 cm x 1.78 cm
- 1.32 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, integrated memory controller, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s - TCG Opal Encryption 2
Display
- 12.5" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Codec
- CX11852
- High Definition Audio, Dolby Home Theater v4
Input
- Keyboard, digitizer, TrackPoint, digital pen, UltraNav
- Keyboard Layout
- UK
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260 - M.2 Card
- Ethernet Controller
- Intel I219-V
- Gigabit Ethernet via optional Ethernet (RJ-45) adapter
- Generation
- 4G
- Technology
- UMTS, HSPA, HSPA+, DC-HSPA+, LTE Advanced
- Controller
- Sierra Wireless EM7455 - M.2 Card
- Service Provider
- Lenovo
- Technology
- 4-cell lithium polymer
- Capacity
- 44 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- Interfaces Details
- 2 x USB 3.0 , Mini DisplayPort , HDMI , OneLink+ connector , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSDXC UHS)
Software
- Software Included
- Lenovo Solution Center, Lenovo Companion, Lenovo Settings, SHAREit, REACHit
- Midnight black
- Case Material
- Carbon fibre
- Integrated Options
- Dockable
- Security
- Administrator password, hard drive password, power-on password, 1 USB 3.0 (Always On), 3D gyrometer, 3D accelerometer, 3D magnetometer, 3D compass, MIL-STD-810G tested
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS
- Localization
- TopSeller
- 1.32 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black | In Stock | £16.62 |
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black | In Stock | £17.63 |
