Whether you have the latest ultrabook or a trusty old notebook, the pocket-sized ThinkPad USB-C Wired Compact Mouse will help to up your game. And with up to 2400 on-the-fly DPI adjustment, you can click and scroll more accurately and precisely, wherever your work takes you.
Get More Done, Seamlessly
Take productivity levels to the max with a truly portable mouse that works with precision on almost any surface. Key features include seamless 4-way scrolling (left, right, up, and down) and on-the-fly adjustable DPI controls. -
Eight Can Go Into One
Now, you can wirelessly pair an ultrabook with up to eight input devices, including keyboards and mice, with just one Lenovo USB-C Unified Pairing Receiver. In doing so, it instantly transforms that often underused USB-C port into a world of possibilities. -
Smart by Nature and Design
The Lenovo USB-C Unified Pairing Receiver is designed to help on-the-go professionals make the most of their ultrabooks. Being asymmetrical, it does not block other ports and can also be used to replace a lost unifying receiver.
- Lenovo ThinkPad Compact - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right and left-handed
- 5.8 cm x 10 cm x 3.5 cm
- 55 g
- Wireless Receiver
- USB-C wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 4
- Movement Resolution
- 2400 dpi
- Performance
- 3 million clicks left/right button, million clicks scroll click
- Scrolling wheel (4-way), blue optical sensor, on-the-fly DPI switching, ambidextrous design
- Battery
- AA type
- OS Required
- Google Chrome OS, Windows 10 64-bit Edition
- Package Type
- OEM
- 3-year warranty
- Mouse
- Wireless Receiver
- Orientation
- 5.8 cm
- 10 cm
- 3.5 cm
- 55 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- Buttons Qty
- 4
- 2400 dpi
- Performance
- 1 x USB-C - 24 pin USB-C
- Included Accessories
- 1 AA battery, Lenovo USB-C Unified Pairing Receiver
- CB, FCC, cTUVus, IC, TUV, JRF, VCCI, GB/T 26245, IMDA, NBTC, DWLF&M, TRC, ANRT
- Package Type
- OEM
- AA type
- Run Time (Up To)
- 18 months
- OS Required
- Shipping Width
- 9.4 cm
- Shipping Depth
- 12.6 cm
- Shipping Height
- 4.7 cm
- Shipping Weight
- 132 g
- Limited warranty - replacement - 3 years
- 0 °C
- 40 °C
- 20 - 95%
