Lenovo TP MINI DOCK PLUS SERIES 3 UK
Quicklinx: 784KWS00 Mfr#: *45N6696*
The ThinkPad Mini Dock Plus Series 3 offers convenient, one-step connection to a rich array of peripheral devices. It's ideal for notebook users who have advanced computing requirements but demand a docking solution that is small and easy to use.
  • Versatile connectivity
    With a wide range of ports including 4-pin USB Type-A, 20-pin DisplayPort, eSATA, 15-pin HD D-Sub (HD-15) for VGA, mini-phone 3.5 mm for microphone and headphones, and RJ-45 for Ethernet, this mini-dock offers comprehensive connectivity options for a variety of devices and peripherals.
  • Enhanced display options
    Equipped with two DisplayPort and one VGA connections, the Lenovo ThinkPad Mini Dock Plus Series 3 supports multiple display setups, allowing for expanded visual workspace and increased productivity.
  • Easy integration
    Designed for compatibility with PC systems, this mini-dock seamlessly integrates into existing setups, ensuring a smooth connection with a variety of computer models.
  • Secure and compliant
    Featuring a key lock for security and compliance with multiple standards including BSMI, C-Tick, CB, FCC, MIC, UL, VCCI, and cUL, users can trust in the reliability and safety of their docking solution.
Lenovo ThinkPad Mini Dock Plus Series 3 - mini-dock
Mini-dock
34.5 cm x 19.9 cm x 5.6 cm
0.94 kg
United Kingdom
Power adapter - external
1-year warranty
Mini-dock
34.5 cm
19.9 cm
5.6 cm
0.94 kg
United Kingdom
6 x USB 2.0 - 4 pin USB Type A , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x storage - eSATA , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x display / video - DVI , 1 x microphone - input - mini-phone 3.5 mm , 1 x headphones - output - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x docking / port replicator
Security lock slot (cable lock sold separately), key lock
UL, VCCI, C-Tick, BSMI, cUL, CB, MIC, FCC
Limited warranty - 1 year
