Lenovo TP 90W AC Adapter for X1 Carbon
Quicklinx: 8DJVWS00 Mfr#: 0B47002
Device Type: Laptop
Type: Power Adapter
Device Screen Size: [N/A]
Colour: Black
Hurry, only 1 left in stock!
£44.24 ex VAT
£53.08 inc VAT
Keep a spare ThinkPad 90 W AC Adapter to hand to ensure your ThinkPad has a consistent flow of power. Keep one in the office, one at home and another in your carrying case for immediate, convenient access to power. This ThinkPad AC adapter is perfect for use as a spare or replacement adapter for compatible laptops. It is compatible with all Lenovo laptops with the rectangular "slim-tip" common power plug. It is not compatible with legacy notebook systems with the round, barrel-type power plug. ThinkPad AC adapters are compact so you can easily keep a spare tucked into your carrying case at all times. This 90 W adapter will perform to the exact same standard as the one which originally came with your laptop. It is highly energy efficient and is backed by an official Lenovo one-year warranty.
  • Efficient power delivery
    This power adapter efficiently delivers up to 90 W to meet the power needs of your Lenovo ThinkPad, ensuring a consistent and reliable charge.
  • Compact and portable design
    The slim design of the adapter makes it easy to carry, fitting seamlessly into bags or backpacks for effortless travel.
  • Wide voltage compatibility
    The adapter operates at a broad voltage range of AC 100-240 V, allowing it to work in various locations around the globe.
  • Compliance with safety standards
    Meeting multiple compliance standards such as UL, FCC, and EMC, this adapter provides safe operation.
Lenovo ThinkPad 90W AC Adapter (Slim Tip) - power adapter - 90 Watt
Power adapter - external
360 g
Saudi Arabia, Hong Kong, Singapore, United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
90 Watt
Output connectors
1 x power DC jack
5 cm x 12.6 cm x 3 cm
1-year warranty
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
1 x power DC jack
Power Capacity
90 Watt
Power cable
UL, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, CB, CCC, EMC, PSB, FCC, PSE Mark, ICES, S Mark
Limited warranty - replacement - 1 year
5 °C
8 - 80% (non-condensing)
5 cm
12.6 cm
3 cm
360 g
Device Type: Laptop
Type: Power Adapter
Colour: Black
Brand: Lenovo
Stock Status: While stocks last
Stock Status: Clearance
