Lenovo Tiny-in-One 22 21.5" 1920x1080 4ms DisplayPort IPS LED Monitor
Quicklinx: DWJFWS00 Mfr#: 10R0PAT1UK
The ThinkCentre Tiny-in-One 22 Gen3 Touch + ThinkCentre Tiny could be a modular AIO that comfortably manages your workspace. Tiny-in-One 22 Gen3 Touch with AIO features Equipped with Camera with Mic. for VOIP. Meanwhile keep a borderless LED panel, lift / tilt / pivot / swivel stand, DisplayPort connectivity, and enjoy reliable performance at an affordable price.
Tiny-in-One 22 Gen3 Touch is also a standard monitor which works with all PCs.
Lenovo ThinkCentre Tiny-in-One 22 - Gen 3 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5" - touchscreen
720p webcam, USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms, 4 ms (overdrive), 14 ms (default)
Colour Gamut
72%
Input Connectors
DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
48.93 cm x 27.33 cm x 37.07 cm
5.34 kg
English / Europe
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, VESA DPMS, VESA FPMPMI, RoHS, ISO 9241-307, WEEE, DDC-2B/CI, UL Environmental SPC Gold, VOC, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Diagonal Size
21.5"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Pixel Per Inch
102.4
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Gamut
72%
Response Time
Vertical Refresh Rate
30 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Anti-glare
Backlight Technology
WLED
Wake on Touch
48.93 cm x 27.33 cm x 37.07 cm - with stand
5.34 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touchscreen
DisplayPort/USB 3.1/power (undetachable 3-in-1 cable) , USB 3.1 upstream (Type B) , DisplayPort , USB 3.1 downstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 88% efficiency power supply, Tiny PC dock
Mounting Kit
Optional
English / Europe
Input Voltage
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.93 cm - depth: 27.33 cm - height: 37.07 cm - weight: 5.34 kg , Without stand - width: 48.93 cm - depth: 7.25 cm - height: 33.9 cm - weight: 3.19 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - replacement - 3 years
8 - 80%
