Innovative and elegant with infinity screen and 7.5 mm ultra-slim profile, ThinkVision X24 would be the centrepiece of any desk space. Featuring the next-generation Neo-Blade 23.8-inch panel, the X24 utilises the unique pre-coated metal surface technology in place of a traditional rear cover, enhancing the premium design. Offering not just form over function, the X24 also features an AH-IPS panel with Full HD resolution, making the images vivid and of good quality even at a 178-degree viewing angle. Connectivity options are all digital with DisplayPort and HDMI. It also has a stylish and sturdy chrome stand that is tilt-adjustable for ergonomic viewing.
- Lenovo ThinkVision X24 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 7 ms
- Colour Gamut
- 72%
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Raven black
- 54.09 cm x 22 cm x 41.28 cm
- 3.9 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, RoHS, ISO 9241-307, WEEE
- Display Type
- Diagonal Size
- 23.8"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 94
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- 72%
- Response Time
- 7 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- HDCP
- Raven black
- 3.9 kg
- HDMI , DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Localisation
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 45 °C
- 8 - 80%
