Enhanced connectivity
With built-in USB 3.0 hub and multiple interface options including HDMI and DisplayPort, this monitor offers versatile connectivity for a wide range of devices. -
Superior visual experience
Experience stunning visuals with the 27-inch 4K IPS display, featuring a dynamic contrast ratio of 3000000:1 for deep blacks and bright whites, and wide viewing angles of 178 degrees both horizontally and vertically. -
Ergonomic design
Designed with user comfort in mind, the Lenovo ThinkVision X1 allows for easy display position adjustments including tilt, ensuring a comfortable viewing experience during long work sessions. -
Eco-friendly choice
ENERGY STAR certified and adhering to RoHS standards, this monitor is an environmentally friendly choice, consuming only 32.1 W in on mode, making it efficient without sacrificing performance.
- Lenovo ThinkVision X1 - Gen 2 - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/392060
- Energy Class
- Class G
- Power Consumption (On mode)
- 32.1 W
- Microphone, USB 3.0 hub, FHD camera with LED light
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms, 6 ms, 14 ms (grey-to-grey)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, Thunderbolt 3
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 60.974 cm x 3.27 cm x 35.171 cm
- 4.29 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- UL, RoHS, China Energy standard Tier 2
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub, FHD camera with LED light
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 60 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- English, German, French, Italian, Russian, Spanish, Japanese, Chinese
- Anti-glare, Mercury free, arsenic free, 99% sRGB colour gamut
- Black
- 4.29 kg
Audio
- Speakers
Input
- Microphone
- HDMI , DisplayPort , Headphone/microphone combo jack , USB-C , 4 x USB 3.0 downstream , Thunderbolt
Mechanical
- Tilt
- Tilt Angle
- -5/+30
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x Thunderbolt cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- OS Required
- Microsoft Windows 7 / 10
- Dimensions & Weight Details
- With stand - width: 60.974 cm - depth: 12.305 cm - height: 23.481 cm - weight: 5.59 kg , Without stand - width: 60.974 cm - depth: 3.27 cm - height: 35.171 cm - weight: 4.29 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 8 - 80%
