Lenovo ThinkVision X1 (2nd Gen) 27" 3840x2160 HDMI DisplayPort Thunderbolt IPS LED Monitor
Quicklinx: FGN5WS00 Mfr#: 61C2GAT1UK
  • Enhanced connectivity
    With built-in USB 3.0 hub and multiple interface options including HDMI and DisplayPort, this monitor offers versatile connectivity for a wide range of devices.
  • Superior visual experience
    Experience stunning visuals with the 27-inch 4K IPS display, featuring a dynamic contrast ratio of 3000000:1 for deep blacks and bright whites, and wide viewing angles of 178 degrees both horizontally and vertically.
  • Ergonomic design
    Designed with user comfort in mind, the Lenovo ThinkVision X1 allows for easy display position adjustments including tilt, ensuring a comfortable viewing experience during long work sessions.
  • Eco-friendly choice
    ENERGY STAR certified and adhering to RoHS standards, this monitor is an environmentally friendly choice, consuming only 32.1 W in on mode, making it efficient without sacrificing performance.
Lenovo ThinkVision X1 - Gen 2 - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/392060
Energy Class
Class G
Power Consumption (On mode)
32.1 W
Microphone, USB 3.0 hub, FHD camera with LED light
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms, 6 ms, 14 ms (grey-to-grey)
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, Thunderbolt 3
Display Position Adjustments
Tilt
Voltage
60.974 cm x 3.27 cm x 35.171 cm
4.29 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
UL, RoHS, China Energy standard Tier 2
3-year warranty
Display Type
Energy Class
Class G
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 60 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Colour Temperature
6500K
OSD Languages
English, German, French, Italian, Russian, Spanish, Japanese, Chinese
Anti-glare, Mercury free, arsenic free, 99% sRGB colour gamut
4.29 kg
Audio
Speakers
Input
Microphone
HDMI , DisplayPort , Headphone/microphone combo jack , USB-C , 4 x USB 3.0 downstream , Thunderbolt
Mechanical
Tilt
Tilt Angle
-5/+30
1 x HDMI cable - 1.8 m , 1 x Thunderbolt cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
32.1 W
32.1 kWh/1000h
Power Consumption (Typical)
65 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand - width: 60.974 cm - depth: 12.305 cm - height: 23.481 cm - weight: 5.59 kg , Without stand - width: 60.974 cm - depth: 3.27 cm - height: 35.171 cm - weight: 4.29 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
45 °C
8 - 80%
