Do more than just optimize your productivity with the ThinkVision T32h-20 monitor. Get an enhanced view of and easily navigate through documents, spreadsheets, or designs on this sleek display that complements your modern workspace. Its vast 31.5-inch screen with QHD resolution delivers more screen real estate with higher clarity than FHD, making data-intensive work, number crunching, and content editing a breeze. The one-cable solution USB Type-C, HDMI, and DP ports provide multiple interface options. Integrated with Smart Power the USB Type-C also doubles up as a charger for dynamic consumption and intelligent power management.
More Ways to Multitask
Experience detailed view with 2560 x 1440 resolution on its 31.5-inch wide display. Working on text-heavy documents or large spreadsheets is a breeze, thanks to the monitor's 3-side NearEdgeless bezels that also enable you to use a multi-screen setup. Content and video creators can experience more pixels and vivid images with the 99% sRGB color gamut. This monitor also has an anti-glare screen, making it perfect for open offices. -
Powered to Drive Productivity
This extended USB-C Hub Monitor offers a one-cable solution for power, data, video, and audio transfers. HDMI ports and dedicated DisplayPort enables seamless multi-tasking so you can connect the monitor to your laptop, smartphone, or any other smart device and work efficiently. The Smart Power function detects overall power consumption and dynamically manages the power delivery to each device. It offers up to 75W of power delivery through the USB Type-C cable, reducing maximum power consumption. -
Optimized Workspace
A smart choice for the modern workplace, the ThinkVision T32h-20 offers comfortable viewing for enhanced collaboration. Adjust the screen as per your convenience with a high lift range and tilt angle, along with swivel and pivot functionality. Organize your desk space and maximize productivity with flexible cable management, an integrated phone holder, a minimized square base, and VESA mount capability.
- Lenovo ThinkVision T32h-20 - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/297939
- Energy Class
- Class E
- Power Consumption (On mode)
- 26.5 W
- USB 3.1 Gen 1 hub, USB PD 75 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2727 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 14 ms, 6 ms, 4 ms (extreme mode)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 71.46 cm x 23.5 cm x 46.94 cm
- 9.85 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- CCC, RoHS, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.1 Gen 1 hub
- USB Power Delivery
- 75 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2727 mm
- Pixel Per Inch
- 94
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Integrated cable management, 3-side NearEdgeless, 99% sRGB colour gamut
- Raven black
- 71.46 cm x 23.5 cm x 46.94 cm - with stand
- 9.85 kg
- DisplayPort , HDMI , Headphones , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB 3.1 Gen 1 downstream , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 75W)
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB-C cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26.5 W
- Power Consumption SDR (On mode)
- 26.5 kWh/1000h
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand (highest position) - width: 71.46 cm - depth: 23.5 cm - height: 60.44 cm - weight: 9.85 kg , With stand (lowest position) - width: 71.46 cm - depth: 23.5 cm - height: 46.94 cm - weight: 9.85 kg , Without stand - width: 71.46 cm - depth: 5.1 cm - height: 42.6 cm - weight: 6.78 kg
- Shipping Width
- 84.5 cm
- Shipping Depth
- 52.8 cm
- Shipping Height
- 19 cm
- Shipping Weight
- 12.96 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 3 years
