Lenovo ThinkVision T32h-20 32" 2560x1440 4ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: FPVDWS00 Mfr#: 61F1GAT2UK
Do more than just optimize your productivity with the ThinkVision T32h-20 monitor. Get an enhanced view of and easily navigate through documents, spreadsheets, or designs on this sleek display that complements your modern workspace. Its vast 31.5-inch screen with QHD resolution delivers more screen real estate with higher clarity than FHD, making data-intensive work, number crunching, and content editing a breeze. The one-cable solution USB Type-C, HDMI, and DP ports provide multiple interface options. Integrated with Smart Power the USB Type-C also doubles up as a charger for dynamic consumption and intelligent power management.
  • More Ways to Multitask
    Experience detailed view with 2560 x 1440 resolution on its 31.5-inch wide display. Working on text-heavy documents or large spreadsheets is a breeze, thanks to the monitor's 3-side NearEdgeless bezels that also enable you to use a multi-screen setup. Content and video creators can experience more pixels and vivid images with the 99% sRGB color gamut. This monitor also has an anti-glare screen, making it perfect for open offices.
  • Powered to Drive Productivity
    This extended USB-C Hub Monitor offers a one-cable solution for power, data, video, and audio transfers. HDMI ports and dedicated DisplayPort enables seamless multi-tasking so you can connect the monitor to your laptop, smartphone, or any other smart device and work efficiently. The Smart Power function detects overall power consumption and dynamically manages the power delivery to each device. It offers up to 75W of power delivery through the USB Type-C cable, reducing maximum power consumption.
  • Optimized Workspace
    A smart choice for the modern workplace, the ThinkVision T32h-20 offers comfortable viewing for enhanced collaboration. Adjust the screen as per your convenience with a high lift range and tilt angle, along with swivel and pivot functionality. Organize your desk space and maximize productivity with flexible cable management, an integrated phone holder, a minimized square base, and VESA mount capability.
Lenovo ThinkVision T32h-20 - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/297939
Energy Class
Class E
Power Consumption (On mode)
26.5 W
USB 3.1 Gen 1 hub, USB PD 75 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2727 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
14 ms, 6 ms, 4 ms (extreme mode)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
71.46 cm x 23.5 cm x 46.94 cm
9.85 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
32"
Built-in Devices
USB 3.1 Gen 1 hub
USB Power Delivery
75 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2727 mm
Pixel Per Inch
94
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 3-side NearEdgeless, 99% sRGB colour gamut
Raven black
71.46 cm x 23.5 cm x 46.94 cm - with stand
9.85 kg
DisplayPort , HDMI , Headphones , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB 3.1 Gen 1 downstream , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 75W)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
180
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
26.5 W
26.5 kWh/1000h
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (highest position) - width: 71.46 cm - depth: 23.5 cm - height: 60.44 cm - weight: 9.85 kg , With stand (lowest position) - width: 71.46 cm - depth: 23.5 cm - height: 46.94 cm - weight: 9.85 kg , Without stand - width: 71.46 cm - depth: 5.1 cm - height: 42.6 cm - weight: 6.78 kg
Shipping Width
84.5 cm
Shipping Depth
52.8 cm
Shipping Height
19 cm
Shipping Weight
12.96 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
