Brand
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: FPV6WS00 Mfr#: 61EDGAT2UK
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Interfaces: HDMI, DisplayPort
£329.42 ex VAT
£395.30 inc VAT
Lenovo ThinkVision T27q-20 - LED monitor - 27" (27" viewable) - 2560 x 1440 QHD - IPS - 350 cd/m² - 1000:1 - 4 ms - HDMI, DisplayPort - raven black
LED-backlit LCD monitor - 27"
Energy Class
Class E
Power Consumption (On mode)
21.2 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 14 ms (Off), 6 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
20.8 cm x 61.4 cm x 42.94 cm
7.44 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
27"
Built-in Devices
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 3-side NearEdgeless, 99% sRGB colour gamut
Raven black
20.8 cm x 61.4 cm x 42.94 cm - with stand
7.44 kg
DisplayPort , HDMI , Headphones , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB 3.1 Gen 1 downstream , USB 3.1 Gen 1 upstream (Type B)
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
180
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-B to USB-A cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
21.2 W
21.2 kWh/1000h
Power Consumption (Typical)
23 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (lowest position) - width: 20.8 cm - depth: 61.4 cm - height: 42.94 cm - weight: 7.44 kg , With stand (highest position) - width: 20.8 cm - depth: 61.4 cm - height: 56.44 cm - weight: 7.44 kg , Without stand - width: 4.67 cm - depth: 61.4 cm - height: 36.91 cm - weight: 4.93 kg
Shipping Width
48 cm
Shipping Depth
69.4 cm
Shipping Height
16.3 cm
Shipping Weight
9.59 kg
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
FPV6 Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.71
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Lenovo
