Lenovo ThinkVision T27P-30 27" 3840x2160 4ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: HS6VWS00 Mfr#: 63A9GAT1UK
£498.96 ex VAT
£598.75 inc VAT
The right display can make or break your work, especially if you're keeping track of multiple things at once. Data and financial analysts, creative professionals, and developers all depend on having robust displays that display their efforts accurately every time. T27p-30 ticks all those boxes. Made to deliver near-perfect visual experiences, it is also a highly ergonomic device made with the user in mind. It also goes above and beyond with a wide range of ports for highly practical connectivity. The incredibly thin bezel on its 3-side NearEdgeless design makes adding multiple monitors a breeze. Its incredible Ultra HD resolution (3840 x 2160), paired with In-Plane Switching and wide viewing angle delivers impressive visual clarity.
  • Distraction-free clarity
    Most work today is highly visual, regardless of whether it's content creation or not. Data analysts, coders, financial traders, architects– everyone in these occupations– and more besides, need to see what they're doing. The display quality makes a huge difference as well, and in some cases, helps identify and correct errors that could have serious consequences. The ThinkVision T27p-30 offers crystal-clear clarity and 4K resolution (3840 x 2160). In-Plane Switching ensures consistent visual clarity. The narrow bezel design and multiple ports allow connecting multiple monitors for better versatility and more screen space.
  • Versatile connectivity
    Having a versatile system that handles multiple tasks at once is a blessing. A monitor is a big part of that too, and the right one makes the most complex of tasks a breeze to handle. ThinkVision T27p-30 is armed with a host of ports designed for convenience. The USB-C Gen2 and Display Port allow users to string multiple monitors together. The HDMI 2.0 brings seamless high-definition connectivity to life, and the RJ45 port allows a direct network connection. The audio-out can be used to connect a speaker or headset.
  • Considerate design
    Long hours in front of a monitor are almost guaranteed, no matter what you do. Employees on average spend at least 6 hours in front of a screen, sometimes more. So, user comfort, both in terms of ergonomics and reduced eye strain is vital. The monitor's Natural Low Blue Light technology and TÜV Rheinland Eye Comfort certified technology care for your eyes without affecting color accuracy. ThinkVision T27p-30 comes with a host of features that provide a comfortable user experience in every way. Its stand rises to 150mm to accommodate different heights and work modes, and a wider 35° tilt. ThinkVision T27p-30 is also incredibly good at using less space. Its smaller base means it can be pushed closer to the edge. The built-in phone rack is a convenient place to always keep your phone in sight– so you never miss a message or call.
Lenovo ThinkVision T27p-30 - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
USB 3.2 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.155 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 14 ms (Off), 6 ms (typical)
Colour Support
16.9 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
61.36 cm x 20.45 cm x 54.54 cm
10.4 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
CCC, RoHS 2011/65/EU, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, TUV Eyesafe Display Certification, TUV Rheinland Low Blue Light (Hardware Solution)
3-year warranty
Display Type
Diagonal Size
27"
Built-in Devices
USB 3.2 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.155 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Eye comfort mode, 3-side NearEdgeless, 10-bit(8-bit + A-FRC) Colour Depth, Natural Low Blue Light technology, modular camera support, modular soundbar support
61.36 cm x 20.45 cm x 54.54 cm - with stand
10.4 kg
HDMI , DisplayPort 1.4 , 3 x USB-C 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (BC 1.2) , Audio line-out , USB-C 3.2 Gen 2
Mechanical
Tilt Angle
-5/+23.5
Swivel Angle
90
Rotation Angle
180
Height Adjustment
155 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C to USB-A cable - 1.8 m , 1 x power cable - 1.8 m , 1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
29 Watt
Power Consumption (Max)
91 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10, Windows 11
Dimensions & Weight Details
With stand (lowest position) - width: 61.36 cm - depth: 20.45 cm - height: 39.04 cm - weight: 7.3 kg , With stand (highest position) - width: 61.36 cm - depth: 20.45 cm - height: 54.54 cm - weight: 7.3 kg , Without stand - width: 61.36 cm - depth: 5 cm - height: 36.35 cm - weight: 5.3 kg
Shipping Width
69 cm
Shipping Depth
14.8 cm
Shipping Height
52.5 cm
Shipping Weight
10.4 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
Brand: Lenovo
