The right display can make or break your work, especially if you're keeping track of multiple things at once. Data and financial analysts, creative professionals, and developers all depend on having robust displays that display their efforts accurately every time. T27p-30 ticks all those boxes. Made to deliver near-perfect visual experiences, it is also a highly ergonomic device made with the user in mind. It also goes above and beyond with a wide range of ports for highly practical connectivity. The incredibly thin bezel on its 3-side NearEdgeless design makes adding multiple monitors a breeze. Its incredible Ultra HD resolution (3840 x 2160), paired with In-Plane Switching and wide viewing angle delivers impressive visual clarity.
                Distraction-free clarityMost work today is highly visual, regardless of whether it's content creation or not. Data analysts, coders, financial traders, architects– everyone in these occupations– and more besides, need to see what they're doing. The display quality makes a huge difference as well, and in some cases, helps identify and correct errors that could have serious consequences. The ThinkVision T27p-30 offers crystal-clear clarity and 4K resolution (3840 x 2160). In-Plane Switching ensures consistent visual clarity. The narrow bezel design and multiple ports allow connecting multiple monitors for better versatility and more screen space.
                Versatile connectivityHaving a versatile system that handles multiple tasks at once is a blessing. A monitor is a big part of that too, and the right one makes the most complex of tasks a breeze to handle. ThinkVision T27p-30 is armed with a host of ports designed for convenience. The USB-C Gen2 and Display Port allow users to string multiple monitors together. The HDMI 2.0 brings seamless high-definition connectivity to life, and the RJ45 port allows a direct network connection. The audio-out can be used to connect a speaker or headset.
                Considerate designLong hours in front of a monitor are almost guaranteed, no matter what you do. Employees on average spend at least 6 hours in front of a screen, sometimes more. So, user comfort, both in terms of ergonomics and reduced eye strain is vital. The monitor's Natural Low Blue Light technology and TÜV Rheinland Eye Comfort certified technology care for your eyes without affecting color accuracy. ThinkVision T27p-30 comes with a host of features that provide a comfortable user experience in every way. Its stand rises to 150mm to accommodate different heights and work modes, and a wider 35° tilt. ThinkVision T27p-30 is also incredibly good at using less space. Its smaller base means it can be pushed closer to the edge. The built-in phone rack is a convenient place to always keep your phone in sight– so you never miss a message or call.
- Lenovo ThinkVision T27p-30 - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- USB 3.2 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.155 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1300:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 14 ms (Off), 6 ms (typical)
- Colour Support
- 16.9 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 61.36 cm x 20.45 cm x 54.54 cm
- 10.4 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- CCC, RoHS 2011/65/EU, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, TUV Eyesafe Display Certification, TUV Rheinland Low Blue Light (Hardware Solution)
- 3-year warranty
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.2 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.155 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Eye comfort mode, 3-side NearEdgeless, 10-bit(8-bit + A-FRC) Colour Depth, Natural Low Blue Light technology, modular camera support, modular soundbar support
- Black
- 61.36 cm x 20.45 cm x 54.54 cm - with stand
- 10.4 kg
- HDMI , DisplayPort 1.4 , 3 x USB-C 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (BC 1.2) , Audio line-out , USB-C 3.2 Gen 2
Mechanical
- Tilt Angle
- -5/+23.5
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 155 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB-C to USB-A cable - 1.8 m , 1 x power cable - 1.8 m , 1 x HDMI cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 29 Watt
- Power Consumption (Max)
- 91 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- OS Required
- Windows 10, Windows 11
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.36 cm - depth: 20.45 cm - height: 39.04 cm - weight: 7.3 kg , With stand (highest position) - width: 61.36 cm - depth: 20.45 cm - height: 54.54 cm - weight: 7.3 kg , Without stand - width: 61.36 cm - depth: 5 cm - height: 36.35 cm - weight: 5.3 kg
- Shipping Width
- 69 cm
- Shipping Depth
- 14.8 cm
- Shipping Height
- 52.5 cm
- Shipping Weight
- 10.4 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
