The ThinkVision T27p is designed to provide you with a spectacular viewing experience. The NearEdgeless screen and 3840 x 2160 resolution make it an excellent productivity tool. The USB Type-C port provides a perfect one-cable solution by transiting data, video, and providing power delivery to compatible devices. Multiple USB ports enable easy connectivity to peripherals, making it a truly great investment for professionals in any industry who rely on additional monitors to multitask. Moreover, the ergonomically designed stand with lift, tilt, pivot, and swivel functionalities allows you to adjust the monitor for your comfort.
Wider Viewing Angle
With the In-Plane Switching technology, and UHD resolution with 1.07 Billion colors, you are assured of crystal-clear picture quality, more natural colors, and wider viewing angles. The ThinkVision T27p-10 provides 4ms response time to minimize motion blur caused by fast-moving images for a superior visual experience. -
Versatile Connectivity
The ThinkVision T27p-10 USB-C Hub Monitor helps you eliminate cable clutter with a single, all-in-one data, video, and power connector-the USB Type-C. This coupled with HDMI 2.0, DP 1.2, and four USB 3.1 Gen1 ports will help you effortlessly connect multiple peripherals at once. It also supports Smart Power technology* that manages power consumption and delivery -
Enhanced User Experience
Reduce the strain on your back and neck with a fully ergonomic monitor stand. Lift, tilt, pivot, or swivel the monitor to adjust it as per your convenience. Protect your eyes from blue light emission with the TÜV Eye Comfort certified anti-glare screen. The ThinkVision T27p-10 also supports a soundbar and a ThinkCentre Tiny desktop to further enhance your computing experience.
- Lenovo ThinkVision T27p-10 - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Power Consumption (On mode)
- 29.7 W
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 6 ms, 14 ms (grey-to-grey), 4 ms (extreme)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99%
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- 61.16 cm x 21 cm x 40.33 cm
- 6.95 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- CCC, RoHS, UL Environmental SPC Gold, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99%
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- 61.16 cm x 21 cm x 40.33 cm - with stand
- 6.95 kg
- HDMI ¦ DisplayPort ¦ USB-C ¦ USB 3.1 Gen 1 downstream with Battery Charging ¦ 4 x USB 3.1 Gen 1 downstream ¦ Headphones
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x USB-C cable - 1.8 m ¦ 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 29.7 W
- Power Consumption SDR (On mode)
- 29.7 kWh/1000h
- Power Consumption (Typical)
- 50 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.16 cm - depth: 21 cm - height: 40.33 cm - weight: 6.95 kg ¦ Without stand - width: 61.16 cm - depth: 4.5 cm - height: 36.84 cm - weight: 5 kg
- Shipping Width
- 45.3 cm
- Shipping Depth
- 73.2 cm
- Shipping Height
- 21 cm
- Shipping Weight
- 11 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.1
- Limited warranty - 3 years
