The Lenovo ThinkVision T27i-10 is a high-performance monitor that offers long-term productivity for intense data and graphic applications. With the wide, borderless In-Plane Switching display for enhanced visual experience, and multiple ports for versatile connectivity, the ThinkVision T27i-10 lets you explore your potential and realize it.
- Lenovo ThinkVision T27i-10 - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Power Consumption (On mode)
- 17.4 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 6 ms (typical)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- Dimensions (WxDxH) - with stand (highest position)
- 61.19 cm x 26.98 cm x 51.33 cm
- 6.55 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- CCC, DDC/CI, RoHS, China Energy standard Tier 2, VESA TMDS, TUV Rheinland Eye Comfort Certification
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Pixel Per Inch
- 82
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 54 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Anti-glare
- Raven black
- 61.19 cm x 26.98 cm x 51.33 cm - with stand (highest position)
- 6.55 kg
- HDMI , VGA (HD-15) , DisplayPort , Headphones , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 17.4 W
- Power Consumption SDR (On mode)
- 17.4 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows 7 / 10
- Dimensions & Weight Details
- With stand (highest position) - width: 61.19 cm - depth: 26.98 cm - height: 51.33 cm - weight: 6.55 kg , With stand (lowest position) - width: 61.19 cm - depth: 26.98 cm - height: 40.33 cm - weight: 6.55 kg , Without stand - width: 61.19 cm - depth: 4.99 cm - height: 36.65 cm - weight: 4.6 kg
- Shipping Width
- 71.5 cm
- Shipping Depth
- 18.7 cm
- Shipping Height
- 45.5 cm
- Shipping Weight
- 9.32 kg
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
