Brand
Lenovo ThinkVision T27i 27" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FGN4WS00 Mfr#: 61C6MAT1UK
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 6ms
Interfaces: VGA (HD-15), DisplayPort, HDMI
£251.26 ex VAT
£301.51 inc VAT
The Lenovo ThinkVision T27i-10 is a high-performance monitor that offers long-term productivity for intense data and graphic applications. With the wide, borderless In-Plane Switching display for enhanced visual experience, and multiple ports for versatile connectivity, the ThinkVision T27i-10 lets you explore your potential and realize it.
Lenovo ThinkVision T27i-10 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Power Consumption (On mode)
17.4 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
6 ms (typical); 4 ms (extreme)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
Raven black
Dimensions (WxDxH) - with stand (highest position)
61.19 cm x 26.98 cm x 51.33 cm
6.55 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
CCC, DDC/CI, RoHS, China Energy standard Tier 2, VESA TMDS, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
54 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Anti-glare, 72% colour gamut
Raven black
61.19 cm x 26.98 cm x 51.33 cm - with stand (highest position)
6.55 kg
HDMI , VGA (HD-15) , DisplayPort , Headphones , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
17.4 W
17.4 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand (highest position) - width: 61.19 cm - depth: 26.98 cm - height: 51.33 cm - weight: 6.55 kg , With stand (lowest position) - width: 61.19 cm - depth: 26.98 cm - height: 40.33 cm - weight: 6.55 kg , Without stand - width: 61.19 cm - depth: 4.99 cm - height: 36.65 cm - weight: 4.6 kg
Shipping Width
71.5 cm
Shipping Depth
18.7 cm
Shipping Height
45.5 cm
Shipping Weight
9.32 kg
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - 3 years
10 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 6ms
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Lenovo
