Whether you call in from home, work in an open office or constantly shift your base of operations, ThinkVision T27hv-20 makes collaboration across distance easy for modern employees like you. That's because it puts every feature you need at your fingertips while taking commonly faced problems out of the picture. It's a pro at handling image and sound to give a world-class videoconferencing experience. On top of all the features you'd hope for, like 1080p IRRGB webcam, noise-canceling mics and powerful speakers, T27hv-20 comes packed with advanced features. For instance, while you're in the middle of a conference call or just plain busy, the on-air style Smart Traffic Light comes on to warn colleagues, or excited children, not to disturb you. To optimize energy efficiency, Smart Energy turns off your screen when it senses that you've moved away from your desk. And because ThinkVision T27hv-20 is a USB-C hub monitor, it has superb connectivity: with a single cable, you can transfer data, video and even Ethernet signals all at once, and even daisy chain a second monitor by DP out port for greater productivity.
- Lenovo ThinkVision T27hv-20 - LED monitor - QHD - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Energy Consumption per Year
- 66.47 kWh
- Power Consumption (On mode)
- 27.3 W
- Microphone, 1080p webcam
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 14 ms (Off), 6 ms (typical)
- Colour Support
- 16.7 million colours (8-bit)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 60.86 cm x 20.8 cm x 61.36 cm
- 7.35 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- CCC, TUV Rheinland Low Blue Light Certification, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 66.47 kWh
- Diagonal Size
- 27"
- Built-in Devices
- 1080p webcam
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 114 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Smart Display Sensor, integrated cable management, 3-sided bezeless
- Raven black
- 60.86 cm x 20.8 cm x 61.36 cm - with stand
- 7.35 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
Input
- Microphone
- HDMI , DisplayPort , DisplayPort output , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , 3 x USB 3.2 Gen 1 downstream , Audio line-in/out , Network
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), 90W power delivery
- Cables Included
- 1 x USB-C to USB-C cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 27.3 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Included Software
- ThinkColor
- Dimensions & Weight Details
- With stand - width: 61.36 cm - depth: 20.8 cm - height: 60.86 cm - weight: 7.35 kg , Without stand - width: 61.36 cm - depth: 4.55 cm - height: 41.26 cm - weight: 4.85 kg
- Shipping Width
- 86 cm
- Shipping Depth
- 51.5 cm
- Shipping Height
- 15.9 cm
- Shipping Weight
- 10.55 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
