Lenovo ThinkVision T27hv-20 27" 2560x1440 6ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: GK6RWS00 Mfr#: 62A9GAT1UK
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
Hurry, only 1 left in stock!
£390.09 ex VAT
£468.10 inc VAT
Whether you call in from home, work in an open office or constantly shift your base of operations, ThinkVision T27hv-20 makes collaboration across distance easy for modern employees like you. That's because it puts every feature you need at your fingertips while taking commonly faced problems out of the picture. It's a pro at handling image and sound to give a world-class videoconferencing experience. On top of all the features you'd hope for, like 1080p IRRGB webcam, noise-canceling mics and powerful speakers, T27hv-20 comes packed with advanced features. For instance, while you're in the middle of a conference call or just plain busy, the on-air style Smart Traffic Light comes on to warn colleagues, or excited children, not to disturb you. To optimize energy efficiency, Smart Energy turns off your screen when it senses that you've moved away from your desk. And because ThinkVision T27hv-20 is a USB-C hub monitor, it has superb connectivity: with a single cable, you can transfer data, video and even Ethernet signals all at once, and even daisy chain a second monitor by DP out port for greater productivity.
Lenovo ThinkVision T27hv-20 - LED monitor - QHD - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
66.47 kWh
Power Consumption (On mode)
27.3 W
Microphone, 1080p webcam
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 14 ms (Off), 6 ms (typical)
Colour Support
16.7 million colours (8-bit)
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Raven black
60.86 cm x 20.8 cm x 61.36 cm
7.35 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
CCC, TUV Rheinland Low Blue Light Certification, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, EU RoHS 2002/95/EC
3-year warranty
Display Type
Energy Class
Class F
66.47 kWh
Diagonal Size
27"
Built-in Devices
1080p webcam
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 114 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Smart Display Sensor, integrated cable management, 3-sided bezeless
Raven black
60.86 cm x 20.8 cm x 61.36 cm - with stand
7.35 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
Input
Microphone
HDMI , DisplayPort , DisplayPort output , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , 3 x USB 3.2 Gen 1 downstream , Audio line-in/out , Network
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
180
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 90W power delivery
1 x USB-C to USB-C cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
27.3 W
26 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
ThinkColor
Dimensions & Weight Details
With stand - width: 61.36 cm - depth: 20.8 cm - height: 60.86 cm - weight: 7.35 kg , Without stand - width: 61.36 cm - depth: 4.55 cm - height: 41.26 cm - weight: 4.85 kg
Shipping Width
86 cm
Shipping Depth
51.5 cm
Shipping Height
15.9 cm
Shipping Weight
10.55 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Lenovo
