This outstanding professional monitor is built for collaboration and conferencing with an integrated webcam, microphone and speakers. But there's no sacrificing display performance with bright, rich color and near-edgeless In-Plane Switching panel to ensure optimized visual experience. This excellent VoIP solution features a full range of connectivity options and full-function stand to suit any environment.
Easy conferencing
Conference calls are a breeze with integrated webcam with privacy lock, speakers and microphone. -
Easy sign-in
With Windows Hello supported devices such as smartwatches, smart bracelets or smartphones, you'll get enhanced security without having to type in a password. -
Easy on the eyes
The near-edgeless In-Plane Switching screen provides exceptional visuals across wide-viewing angles.
- Lenovo ThinkVision T24v-10 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Microphone, USB 3.0 hub, FHD IR camera
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (extreme), 6 ms (typical)
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.02 cm x 26.19 cm x 50.05 cm
- 5.07 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI
- 3-year warranty
- Display Type
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.0 hub, FHD IR camera
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 92
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 81 kHz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- WLED
- HDCP
- Black
- 54.02 cm x 26.19 cm x 50.05 cm - with stand
- 5.07 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
Input
- Microphone
- HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream , 2 x USB 3.0 downstream , Headphone/microphone combo jack
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x USB cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
- 0 °C
- 40 °C
- 10 - 80%
