Lenovo ThinkVision T24t-20 23.8" 4ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: GSMPWS00 Mfr#: 62C5GAT1UK
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: USB-C, DisplayPort, HDMI
£191.66 ex VAT
£229.99 inc VAT
Business opportunities are at your fingertips if you're able to take advantage of touch. ThinkVision T24t-20 puts success in both your hands thanks to its touch-screen panel display that recognizes input from 10 points at once. That lets you control different areas of the screen simultaneously. And with touch sensors, you can draw and edit images with precision and work with apps that use variable touch. Its high-resolution, anti-glare, 3-side NearEdgeless screen that can operate even without a stand makes it ideal for transforming public-facing scenarios and home working moments into literal touch points. With multiple options for connectivity, this docking monitor lets you connect to desktops, laptops. T24t-20 lets you use that touch input to control them when they're connected, giving you the intuitive mastery of your IT arsenal. It's made possible by the USB Type-C port that provides a true 1-cable solution, removing additional cables and complex setups, to enable touch. That single cable transfers both data and video signals and can even power your connected devices through Lenovo Smart Power management without extra power cables clogging up your workspace.
Lenovo ThinkVision T24t-20 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/573029
Energy Class
Class F
Power Consumption (On mode)
20 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
CCC, TUV Rheinland Eye Comfort Certification, EU RoHS 2002/95/EC, TUV Hardware Low Blue Light Certification
Display Type
Energy Class
Class F
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
SmartPower, 3-side NearEdgeless, 99% sRGB colour gamut
Raven black
Input
Touchscreen
DisplayPort 1.2 , HDMI , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery , 4 x USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Audio line-out
Mechanical
Height, tilt
Tilt Angle
-5/+70
Height Adjustment
90 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x USB-C cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
20 W
18 kWh/1000h
Power Consumption Sleep
0.5 watt
Power Consumption (Off Mode)
0.5 watt
Microsoft Windows 7 / 10
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
Diagonal Size: 24in
Response Time: 4ms
Speakers: None
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Lenovo
