The sleek, stylish Lenovo ThinkVision T24d-10 monitor doesn't just display images - it presents them in exceptionally crisp resolutions. Enjoy vivid images across wide viewing angles with no color distortion or reflection. With elegant slim design, the monitor fits in any workspace.
Performance and Productivity
Professional performance defines the WUXGA (1920 x 1200) resolution, over 99% sRGB high color gamut, 1000:1 contrast and In-Plane Switching for exceptional viewing angles across the entire 24" display. -
Productivity at its Finest
A full-function stand ensures your display sports an executive look regardless of whether you swivel, tilt, pivot, or lift. Paired with near-edgeless screen, you can enjoy a clean look and seamless views cross multi-monitor displays. -
Ergonomic and Manageable
The ergonomic full-function stand is perfect for collaboration. It supports the new tiny clamp bracket for easy set-up of the ThinkCentre Tiny. Practical cable management effectively manages desktop clutter.
 - Lenovo ThinkVision T24d-10 - LED monitor - 24"
 - LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/385670
- Energy Class
 - Class D
- Power Consumption (On mode)
 - 15.2 W
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:10
- Native Resolution
 - WUXGA 1920 x 1200
- Pixel Pitch
 - 0.27 mm
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- Response Time
 - 7 ms
- Colour Gamut
 - 99%
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
 - Black
 - 53.32 cm x 26.04 cm x 49.74 cm
 - 5.63 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
 - FCC Class B certified, RoHS, ISO 9241-307, WEEE, VESA DDC 2 B
 - 3-year warranty
- Display Type
- Energy Class
 - Class D
- Diagonal Size
 - 24"
- Built-in Devices
 - USB 3.0 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:10
- Native Resolution
 - WUXGA 1920 x 1200
- Pixel Pitch
 - 0.27 mm
- Pixel Per Inch
 - 94
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- Colour Gamut
 - 99%
- Response Time
 - 7 ms
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Backlight Technology
 - WLED
 - HDCP
 - Black
 - 5.63 kg
 - VGA (HD-15) , HDMI (HDCP) , DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
 - -5/+30
- Swivel Angle
 - 90
- Rotation Angle
 - 90
- Height Adjustment
 - 110 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x USB cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Localisation
- Security Slot Type
 - Kensington security slot
 - 15.2 W
- Power Consumption SDR (On mode)
 - 15.2 kWh/1000h
- Power Consumption (Typical)
 - 22 Watt
- Power Consumption Stand by
 - 0.3 Watt
- Power Consumption Sleep
 - 0.3 Watt
- OS Required
 - Microsoft Windows 7, Windows 10
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
 - Limited warranty - 3 years
