Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FGM5WS00 Mfr#: 61B4MAT1UK
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 7ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£200.80 ex VAT
£240.96 inc VAT
The sleek, stylish Lenovo ThinkVision T24d-10 monitor doesn't just display images - it presents them in exceptionally crisp resolutions. Enjoy vivid images across wide viewing angles with no color distortion or reflection. With elegant slim design, the monitor fits in any workspace.
  • Performance and Productivity
    Professional performance defines the WUXGA (1920 x 1200) resolution, over 99% sRGB high color gamut, 1000:1 contrast and In-Plane Switching for exceptional viewing angles across the entire 24" display.
  • Productivity at its Finest
    A full-function stand ensures your display sports an executive look regardless of whether you swivel, tilt, pivot, or lift. Paired with near-edgeless screen, you can enjoy a clean look and seamless views cross multi-monitor displays.
  • Ergonomic and Manageable
    The ergonomic full-function stand is perfect for collaboration. It supports the new tiny clamp bracket for easy set-up of the ThinkCentre Tiny. Practical cable management effectively manages desktop clutter.
Lenovo ThinkVision T24d-10 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/385670
Energy Class
Class D
Power Consumption (On mode)
15.2 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Colour Gamut
99%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
53.32 cm x 26.04 cm x 49.74 cm
5.63 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
FCC Class B certified, RoHS, ISO 9241-307, WEEE, VESA DDC 2 B
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200
Pixel Pitch
0.27 mm
Pixel Per Inch
94
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Gamut
99%
Response Time
7 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
HDCP
5.63 kg
VGA (HD-15) , HDMI (HDCP) , DisplayPort (HDCP) , 4 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x USB cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
15.2 W
15.2 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Microsoft Windows 7, Windows 10
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 24in
Response Time: 7ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Lenovo
